Results 1 to 4 of 4
Thread: 99 Eldo suspension question
    Oct 2005
    Hi All, I have a 99 Eldo base which needs rear struts since it makes noises when i go over a road bump and slightly slides to the right. It also squeaks when i push the car up and down. i remember reading in this forum that it has both shocks and struts. but a mechanic told me it only has struts. I'M CONFUSED. Also i'm thinking of buying an aftermarket struts kit (link below), do you guys think it'll be good.
    either
    http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
    Or
    at www.rockauto.com (ACDELCO Part # 51512).
    so do i need just struts or both struts and shocks? and will the linked after market sets do my car any good.
    thanks for helping
    Apr 2005
    157
    Re: 99 Eldo suspension question
    I suggest getting or borrowing a Factory Service Manual. It will provide diagnostics that will answer your questions that just simply can not be questioned.
    lry99eldo
    WarrenJ's Avatar
    WarrenJ is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 ETC Sequoia
    Apr 2004
    Long Island, USA
    878
    Quote Originally Posted by faisaljl
    i remember reading in this forum that it has both shocks and struts. but a mechanic told me it only has struts. I'M CONFUSED . . . . so do i need just struts or both struts and shocks?
    You have struts in the front and shocks in the rear.
    I used the aftermarket struts from http://www.bostonsuspension.com mostly because theirs included 'widgets' to suppress the DIC message telling me I had a suspension problem. Dunno if that applies to your year vehicle.
    Regards,
    Warren
  5. #4
    Apr 2005
    50
    It may be your rear knuckles not the shocks,Jack up the rear of your car and see how much play you get at the 3 and 6 o clock positions and then the 12 and 6 o clock positions.If they are worn you will get play,and the symtoms are the rear feels squirrly driving down the road, when you go over bumps the rear seems to jump to the side. and pushing on the side of the rear of the vehicle it will move quite a bit and clunk.
  • You may not post replies
