Passenger-side low beam headlight won't come on in a 1998 Seville STS!
Results 1 to 15 of 15
Cadillac Seville / Cadillac Eldorado Forum Discussion, Passenger-side low beam headlight won't come on in a 1998 Seville STS! in Past Cadillac Vehicle Discussion; I'm getting tired of turning on my right signal light only to hear a fast clicking signal and see a ...
    STSOnly's Avatar
    STSOnly is offline Cadillac Owners Fanatic
    Mar 2004
    131
    I'm getting tired of turning on my right signal light only to hear a fast clicking signal and see a non-flashing, steady right arrow, indicating that my passenger-side headlight is out, so I checked it out. I've tried a couple things, even though the bulb is good. First, I exchanged the driver-side low beam bulb with that of the passenger-side and put it in the driver-side low beam. It worked for the driver-side with no problems. I also switched the bulbs around and it worked again in the driver-side headlight, so the bulb isn't the problem. The bulb is brand new and not blown, but I tried it anyway. Both bulbs don't wprk in the passnger-side.
    Next, I checked the low beam passenger-side fuse under the hood fuse box and it was good. Still, I traded the low beam driver-side fuse with that of the passenger side fuse, and it worked for the driver-side, but not the passenger-side. I even bought a brand new fuse for the passenger-side and it still didn't solve the problem. What else can it be???? All the other bulbs function correctly in the passenger-side headlight. The only light that doesn't come on in the passenger-side headlight is the low beam. Fuse is good. Bulb is good. Has anyone else had this problem??? Does anyone know what I can do next??? Thanks!
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    Re: Passenger-side low beam headlight won't come on in a 1998 Seville STS!
    cut the wires and just splice into the wires on the good side. if anything it will at least get the headlight to come back on.
    68
    82,068
    Check the connector and wiggle the wires. Might just be a dirty or loose connection.
    Trench's Avatar
    Trench is offline Cadillac Owners Fanatic
    Automobile(s): 1991 Eldorado (Gone) ; 2001 Seville SLS (RIP) ; 2005 DeVille
    La Salle County
    32
    228
    Quote Originally Posted by CadillacETC1997
    That may not be a good idea if the car has DRL. I was reading a schematic for the DRL on cadillacs and it appears the DRL are ran through a series. Running in parallel may cause an issue.
    Not to mention it's only patching the problem. Risks overloading the other sides wiring, too.
    I would explain more, but my fingers are killing me.... MY CAR BATTERY JUST DIED!..anyway. BAh
    Dustin
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by STSOnly
    I'm getting tired of turning on my right signal light only to hear a fast clicking signal and see a non-flashing, steady right arrow, indicating that my passenger-side headlight is out, so I checked it out....
    Am I the only one having trouble 'seeing' the connection between turn signals and headlamps???
    mramazingman's Avatar
    mramazingman is offline Cadillac Owners Fanatic
    Automobile(s): 2000 DEVILLE,2001 STS.
    Sep 2005
    FLORIDA
    52
    122
    Have you checked for voltage with a meter? could be wiring harness like ranger mentioned. You can always skin a very small section of the wires (1/8th inch) behind the connector and check for voltage.I have had connectors/harnesses that "look" good but were bad. you can cover the nick in the wire with silicone.
    68
    82,068
    Quote Originally Posted by JimD
    No. I kind of scratched my head on that one too.
    STSOnly's Avatar
    Mar 2004
    131
    Problem solved. Thanks!!!!!!!!!!!!!!!!!!!!!
    Quote Originally Posted by Ranger
    Here's the connection:
    I was wondering why whenever I turned my right signal light on to make a right turn, it clicked fast and the right arrow was steadily lit instead of flashing like it should. Well, I checked out the owners manual and found out that whenever the right turn signal arrow is on steadily, that means that your right head light is out. If you remove your low beam right fuse and turn on your right signal light, you will encounter the same.
    At any rate, thanks Ranger and everybody else that helped out.
    I fixed the headlight. The problem was the plug in the pic that I have attached. I bent it back in place and when I connected the headlight plug to the car plug and turned on the headlights, the right headlight was working properly as it should and I don't have to worry about the steadily lit right turn signal arrow and fast clicking right turn signal noise as well. Thanks again everybody. This site is always the most helpful!
    68
    82,068
    Re: Problem solved. Thanks!!!!!!!!!!!!!!!!!!!!!
    Hmm, I never knew that. You learn something new everyday. Thanks.
    Sep 2003
    Metro ATL
    4,854
    I was wondering why whenever I turned my right signal light on to make a right turn, it clicked fast and the right arrow was steadily lit instead of flashing like it should. Well, I checked out the owners manual....
    What is the page number??
    Sep 2005
    FLORIDA
    52
    122
    I think I'm going to re-read my owners manual again.JIMD was onto the problem,glad it was an easy fix.
    STSOnly's Avatar
    Mar 2004
    131
    Does this mean that you don't believe me lol??? Look at the pics.
    It's on page 2-33 (1998 Seville owner's manual).
    Hell, I might as well cover everyone else as well.
    If you own a 1999 Seville, it's on page 2-36
    If you own a 2001 Seville, it's on page 2-39
    If you own a 2003 or 2004 Seville, it's on page 3-9
    If you own a 2004 Cadillac SRX, it's on page 3-8
    Other years and models, just look under 'turn signals' or 'signals' in the back of your owner's manual.
    Obviously, a lot of people didn't know about this. Don't feel bad because I didn't know either until it happened to me and I consulted the owner's manual. Like Ranger said, you learn something new every day.
    STSOnly's Avatar
    Mar 2004
    131
    Here a pic out of my 1998 Seville manual!
  16. #14
    STSOnly's Avatar
    Mar 2004
    131
    Here's another pic!
  17. #15
    Sep 2003
    Metro ATL
    4,854
    Page 2-33 in my Owner's Manual talks about turn signal arrows that flash rapidly 'may be' caused by a burned-out signal bulb. Turn signal systems using a rapid flash as a warning for bulb failure is not new technology.
    I'm still looking for the connection between rapidly flashing turn signal arrows and headlamps. My education is not complete.
  18. Remove Advertisements
