How to change Tranmission fluid
Results 1 to 11 of 11
Cadillac Seville / Cadillac Eldorado Forum Discussion, How to change Tranmission fluid in Past Cadillac Vehicle Discussion; Do i drain it from the cooler in the radiator or is there a plug on the bottom of the ...
    SilverSLS99's Avatar
    SilverSLS99 is offline Cadillac Owners Member
    Jul 2005
    6
    Do i drain it from the cooler in the radiator or is there a plug on the bottom of the transmission. If there is a plug please describe its location..
    Thanks
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: How to change Tranmission fluid
    You have to remove the transmission pan. Also on the side case, there's a plug that has to be removed to allow more fluid to drain. Once you get the pan off, you can access the side case plug. It's a easy job to do! I changed the fluid and filters on my 2000 STS a year ago.
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    50
    2,817
    Here is a pic of the side case drain plug.
    Don
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    50
    2,817
    Here is a pic of the side case plug.
    Don
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Great pic! And if I remember right, you have to remove that wiring harness that partially covers it to get to the drain plug? I think it's just the one screw that holds it, right?
    94greencaddysls is offline Cadillac Owners Fanatic
    Automobile(s): 94 sls
    Feb 2005
    235
    I never had too but you may find you do which wouldnt hurt anything
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    50
    2,817
    I didn't remove the harness. I had to move it with my finger a little is all.
    Don
    68
    82,063
    Quote Originally Posted by Dadillac
    Don
    Same here.
    It sounds as though you have never done this before, silverSLS99. Once the pan is off, there is a rubber magnet (like a refirigerator magnet) in the pan. Remove it and wipe off the mushy paste (clutch plate residue). Wipe out the filmy residue in the pan as well. Use a torque wrench to properly torque the pan back on. Spread lots of newspaper under the car, it will be messy.
    Jul 2005
    6
    Ok i found everything ,wiped the magnet,it was a mess...I would guess 8 Qts came out. The specs say it takes 18 qrts..My level indicator said it was fine before. Im changing it because i towed a trailer 2200lbs and it said service tranny on the dash info. I have a cooler and the fluid doesnt smell funny or look different. It did however shift alittle different after this. More like my camaro ss with a high stall.At the time i guess it overheated it was slamming into gear and i let it cool down. It has never acted up again but its just alittle different, its not as smooth as it was. When you come to a stop the RPM's dive then it come back up,i think the converter is engaging alittle too long..
    mtflight's Avatar
    mtflight is offline Cadillac Owners Connoisseur
    Automobile(s): 1999 White Diamond ETC
    Jan 2005
    Dallas, TX
    2,538
    There's a procedure, that involves unplugging a cooler line and letting the transmission purge itself into a bucket, as you add new fluid. You stop when it comes out clean. I think it's in the Tech Archive on the main links at the top.
    sjpi1954's Avatar
    sjpi1954 is offline Cadillac Owners Member
    Automobile(s): None
    Oct 2005
    Pensacola
    62
    49
    Gentlemen,
    I just finished changing the transmission fluid and both filters in my '02 SLS. Couldn't have done it without this forum so thanks again, especially to Ranger and CaddyDaddy and the photos of the side sump drain plug. Here's my two cents on the job.
    Tools: 3/8" Ratchet with 4" extension and 10mm and 11mm sockets. The only need for the 11mm is the side sump drain plug. See pictures on this thread.
    Supplies: I used an old shower curtain and did not leave one drop on the driveway. After the job was done I threw said shower curtain in the garbage. We go through those things about twice a year so...4 old cotton rags/towels. 1-11 quart recycling container. New AC Delco Filters (2) in box. I had 13qts of Dexron III but only used 8 qts. Final quantity remains to be seen but I emptied 9 quarts into my 55/gal drum.
    Ramp: I use my drive on ramps but the SLS lower dam will hit it so I cut a 2x12 I had into 2' pieces and used these as drive on ramp assists. They allow you to NOT damage your lower dam by giving you a shallower approach and departure angle. I chose not to jack up the car and use my jack stands. Whatever works best for you.
    Note: Discussion on the electrical harness is good. I personally went ahead and removed the 10mm bolt securing the harness in order to get it out of the way. I did NOT use the new gasket. The one on the pan was completely serviceable and of much better quality than the one one in the box. Also, be sure and reset your Transmission Fluid Life back to 100% on the DIC. Bring it up, Hold Reset Button until all 3 XXXs go to 100%. Make your logbook entry.
    Cost: Fluid and Filter was $42.
    Time: Start to finish including wood cutting was 2.5 hours. I let everything drain completely. No hurry at all. I personally found it easier to loosen up the driver's side bolts first and that corner serve as my drain point. Watch out for the amount of fluid coming out when you unscrew the 11mm side sump plug...Be prepared for a gusher. Eye protection is recommended and I was grateful to be wearing mine. Cleaned pan thoroughly and magnetic mat thoroughly. Test drive was uneventful throughout all gears and speeds. Feels good and shifts smooth. No leaks.
    Never Give Up, Never Surrender...
    JP
  14. Remove Advertisements
