| Cadillac Seville / Cadillac Eldorado Forum Forum for discussions regarding the past Seville and Eldorado. | Cadillac Forums: 91 Eldorado- Engine turns over but won't start
01-09-06, 05:51 PM
| | Cadillac Owners Member | | | | | 91 Eldorado- Engine turns over but won't start Hello,
My 91 eldo will not start. The engine turns over and it says that all monitored systems are OK. Then the battery light comes on and the check oil light comes on and the engine does not catch to start. I had the oil replaced three days ago and the battery was replaced about a week ago. 90K miles. Any help would be greatly appreciated. thanks, Matt |
01-09-06, 09:23 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: 91 Eldorado- Engine turns over but won't start Check your fuel pressure. |
01-10-06, 12:20 AM
| | Cadillac Owners Member | | | | | Re: 91 Eldorado- Engine turns over but won't start Thanks for the reply, how exactly would I go about doing this? Any other input? |
01-10-06, 12:37 AM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: 91 Eldorado- Engine turns over but won't start Get a fuel pressure guage. Locate the shreader valve (looks just like a tire valve) on the fuel rail. Remove the cap and srew on the guage. Turn the key ON to energize the fuel pump and pressurize the fuel system and see what kind of pressure you have. Also see what it reads while cranking. Should be around 45 psi if memory serves me correctly. |
01-10-06, 12:57 AM
| | Cadillac Owners Connoisseur Cadillac(s): 1997 Cadillac Eldorado ETC & 1994 Pontiac Firehawk | | Join Date: Jan 2006 Location: St. Pete, FL Age: 20 | | | Re: 91 Eldorado- Engine turns over but won't start Check your battery cables. I have a similiar problem, it won't turn right away sometimes, I gotta hold it for a few seconds. I asked Dimmit Cadillac and they said the Battery Cables are either coroded or just very dirty. I think he said Coke and Baking Soda on them will clean them right up. Been too lazy to worry bout it. |
01-10-06, 01:27 AM
| | Cadillac Owners Member | | | | | Re: 91 Eldorado- Engine turns over but won't start Cool thanks for the tips, I'm gonna try the battery thing. I wonder if I use jumper cables to give it a little extra boost? |
01-10-06, 01:01 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: 91 Eldorado- Engine turns over but won't start Inspect the battery cables closely. Sometimes corrsion will work its way under the insulation. In that case, they need to be replaced. |
01-13-06, 01:42 PM
| | Cadillac Owners Member | | | | | Re: 91 Eldorado- Engine turns over but won't start Matt, i had the same problem with my eldo.it is more likely being the pick up coil in the distributor if it is a 4.9 engine.you have to takethe dist. out & mark the timing alignment--try this first.it could be the ignition module.it is right under the dist. cap.it's kindof oval shaped,black.&about 2'' long.replace it first.about 14$. if that does'ntwork itcould be the cam switch.it is underneath the round copper disc.it is black,about 1''long,held in by one screw on each end.can bend a small wrench to reach the screws.cam switch is $45.good luck. i'm looking for a power steering pressure switch for a 1992 eldo. sincerely, Rob |
01-13-06, 06:55 PM
| | Cadillac Owners Member | | | | | Re: 91 Eldorado- Engine turns over but won't start I finally found a power steering switch. hope the info. i gave you works.start out with the ign. module first. pick up coil & labor can be expensive. Rob |
01-22-06, 08:20 PM
| | Cadillac Owners Member | | | | | Re: 91 Eldorado- Engine turns over but won't start Turns out it was my fuel pump, $600 later and my caddy's running again. thanks for the help to those who tried. -Matt |
03-07-07, 08:50 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: 91 Eldorado- Engine turns over but won't start Hi, I have a beautiful 91 Eldorado Biarritz 4.9 that won't start either, I've replaced EGR, MAP sensor, Distributor and no start, how did you find out it was the fuel pump |
03-09-07, 05:31 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: 91 Eldorado- Engine turns over but won't start Remove the fuel filler cap. Place your ear to the pipe and have someone turn the key on. You should hear the pump run for about 2 seconds. If not, a fuel pressure guage on the fuel rail service port will confirm it. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
