Do I have to add oil after A/C hose R&R?
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, Do I have to add oil after A/C hose R&R? in Past Cadillac Vehicle Discussion; Hello, I just replaced the high pressure discharge side hose (from compressor to condenser) on my 2000 Seville SLS. The ...
    LewsBlues is offline Cadillac Owners Member
    Automobile(s): 2000 SLS 4.6 Northstar
    Sep 2014
    Lumberton Tx
    1
    Hello,
    I just replaced the high pressure discharge side hose (from compressor to condenser) on my 2000 Seville SLS. The system had leaked down completely. How do I know how much oil I should replace if any? I have the vacuum pump to clear the system, but want to make sure I have enough oil in it! Thanks in advance for your help!
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,365
    Re: Do I have to add oil after A/C hose R&R?
    Quote Originally Posted by LewsBlues View Post
    Hello,
    along with the freon leak -
    was oil also leaking from the bad hose?
    how much oil was in the hose that you replaced?
    add the same amount back to the system -
    68
    81,914
    Chances are you don't need to add any. Unless you have a catastrophic depressurization, oil leakage will be minimal.
