I'M BACK and readyto get started this time - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Cadillac Seville / Cadillac Eldorado Forum Discussion, I'M BACK and readyto get started this time in Past Cadillac Vehicle Discussion; Originally Posted by 74eldog got that right,,, i hosed it down real good the motor doesn't look as bad as ...
  1. #16
    74eldog is offline Cadillac Owners Fanatic
    Automobile(s): 74 Eldorado
    May 2005
    Columbus, Ohio
    149
    Re: I'M BACK and readyto get started this time
    Quote Originally Posted by 74eldog
    got that right,,, i hosed it down real good the motor doesn't look as bad as a i thought it did... makes a big difference out in the open......
    Not sure which way i will go with motor yet,,, if i get it turn i will leave it in, if not, she'll be pulled out..
    I got some pics scanned but not sure how to post them....
    help
  2. #17
    slk230mb's Avatar
    slk230mb is offline Moderator
    Automobile(s): Now: 2008 STS-V, 1960 Eldorado Brougham Then: 2002 Escalade
    Feb 2004
    Bayside, NYC
    31
    5,826
    On the post reply box, click manage attachments. From there you can upload the pictures from your computer.
    ~Steve
  3. #18
    BluEyes's Avatar
    BluEyes is offline Cadillac Owners Enthusiast
    Automobile(s): 1970 Sedan deVille hardtop
    Feb 2005
    595
    As for the rear wheels, the most likely cause would be a stuck parking brake. The cables can get rusted stuck in their sheath after years of sitting.
    The parking brake does release when you put it into D, right?
    Caddy was also experimenting with ABS on the Eldorados starting in the early 70's. This was the first American attempt at it I believe, and on the rear wheels only. Does this car by chance have the "trackmaster" system? I have no clue how it works, but it might be able to malfunction and lock up.
  5. #19
    May 2005
    Columbus, Ohio
    149
    well i couldn't get them to load, i have to resize the file(i guess), will try again later...
  6. #20
    May 2005
    Columbus, Ohio
    149
    Quote Originally Posted by BluEyes
    i posted about my brakes in another forum"locked up....
    Everything will need to be replaced.....rust have taken over....
    Is putting the vehicle in 'd' the only way to release it...because i released it park....lol
  7. #21
    cadillacdeville's Avatar
    cadillacdeville is offline Cadillac Owners Fanatic
    May 2004
    Longview Tx
    31
    250
    If the parking brake is on when you start the car and put it in drive or reverse its got an automatic vacuum actuated release for the Parking brake.
  8. #22
    skidmark is offline Cadillac Owners Member
    Jan 2006
    5
    Sounds like a great project. Keep us up to date. I owned a 72 coupe with the 472 I believe and what a interstate cruiser. Just floated. Like riding a couch. Now own a airboat with a 500 caddi running direct drive. These motors have alot of life to give and deliver more torque down low than my friends 502 who had to purchase a $2800 gear reduction unit to spin a prop. Nice choice.
  9. #23
    May 2005
    Columbus, Ohio
    149
    Quote Originally Posted by cadillacdeville
    Thanks for your comments
    After i pull my heads and get my motor work started, i'm going to replace all the brakes, drums (they're rusted pretty bad), hardware and wheel cylinders.... Hopefully that will get me rollin and STOPPING pretty good...
  10. #24
    May 2005
    Columbus, Ohio
    149
    Quote Originally Posted by skidmark
    Thanks, i can't wait to get this big beast back on the road.....
    Since I was able to rotate the motor by hand I'm only doing a top end rebuild....and of course, i plan to freshen up the engine bay with a coat of paint....
  11. Remove Advertisements
