turned a/c on and smoke starts bellowing from engine bay
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By MoistCabbage
Cadillac Seville / Cadillac Eldorado Forum Discussion, turned a/c on and smoke starts bellowing from engine bay in Past Cadillac Vehicle Discussion; ...
    dizzy1 is offline Cadillac Owners Member
    Aug 2013
    5
    I was sitting in a parking lot on a 95° day waiting for someone and decided to turn the a/c on. All the sudden the rpms start jumping all over the place, sqealing belt? and smoke. It's fine when the a/c is off. Has anyone else had this problem? Bad condenser? Bad bearing? Any idea how hard to fix or replace. Any and all info would be greatly appreciated. Thanks!
    1999 Eldo 68k miles
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Sounds like the compressor is seized. The pulley clutch engaged, the pulley stopped (instead if the compressor spinning) and the belt started rubbing on it and smoking.
    68
    82,083
    Re: turned a/c on and smoke starts bellowing from engine bay
    Yup
    Aug 2013
    5
    Yup
    So does that mean I have to reace the whole compressor or is the a fix?
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,999
    It's the compressor that seizes. How long have you not used your A/C? Or have you had any weird symptoms?
    Feb 2003
    california
    69
    6,666
    You need a compressor, belt and receiver dryer and the system will need to be flushed because all the metal particles from the seized compressor are circulating though the system. I will never understand why people buy a Cadillac with "automatic" climate control and operate it as if it was a manual system in a Chevy? I dont turn the A/C on. I let the system engage the compressor when needed. Every car I've owned with automatic climate control, I set to around 72 degrees in the AUTO mode and leave it alone except for using the defrost button in the winter. Less wear on switches, less wear on the compressor.
    Aug 2013
    5
    Quote Originally Posted by carnut View Post
    I've never had auto climate control before owning this car. I prefer windows down over a/c so I RARELY used it. It just so happened that this day I was waiting on someone and sitting in direct sunlight and decided use it. I will take your advice in the future and set the control to whatever temp and let it do it on it's own. Its just a bummer cause the guy I was waiting on was a person I was hoping to trade vehicles with. Of course, 5 mins before he shows up my car started acting up.
    68
    82,083
    Don't forget the condenser. That too will need to be replaced.
    Sep 2010
    East Boston MA.
    29
    26,325
    And orifice tube.
    Aug 2013
    5
    And orifice tube.
    Is it possible to just replace the clutch on the compressor?
    Sep 2010
    East Boston MA.
    29
    26,325
    Yes, but that won't do you any good. The clutch is working. When it's disengaged, the pulley spins freely. When you turn the A/C on, the clutch engages to spin the compressor. But since yours is seized, it just stops completely, and the belt burns.
    carnut likes this.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,489
    and install an in-line filter in the low side -
    ACDelco 15-1747 - around $30 -
  15. Remove Advertisements
