Post Engine Swap Bugs/Issues
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, Post Engine Swap Bugs/Issues in Past Cadillac Vehicle Discussion; Hey guys, i was hoping i could get some insight to some issues i am having after replacing the motor ...
    Jays03dsg is offline Cadillac Owners Member
    Automobile(s): 2002 Seville STS
    Jan 2005
    37
    Hey guys, i was hoping i could get some insight to some issues i am having after replacing the motor due to the infamous head gasket issue. After having a friend complete the swap the car drives fine except for a rough idle which i think is due to an intake gasket not being seeded correctly. The more important issues i am having i will describe below with attached visuals, although they are strictly electric so i am assuming there could be some faulty sensors that were connected.
    1. For my "gauge cluster" picture, the following items are not working at all: Speedometer, Tachometer, Trip odometers, and the display that keeps track of the total miles on the bottom left of the picture. Also, none of the other information on the DIC message area works either (outside temp, battery voltage, instant mpg, total mpg, etc...) the only thing that shows up is the "check tire pressure" and "service air bag" message. The actual Temperature and Gas gauge work fine.
    2. For the rear view "mirror" picture, it does not display the direction in the top right corner, and the On Star buttons are not activated, in addition to there being a red light displayed, rather than a green light.
    3. For the images that show both of the "DIC Buttons", none of them work at all to display any of the information that is normally found within the actual DIC message display.
    4. My Reverse Sensing system along with the "3-Dot" display above the rear seat is not working when i put the car in reverse.
    5. When i try to use my blinkers, they do not work. I only get the front blinker lamp to stay on constantly (until i have either completed a turn or turn the blinker stick off on the steering column), but none of the rear blinker lamps function at all.
    6. I went to use my emergency brake last night, and when i was leaving and put my car into gear, the pedal itself did not return to its normal position. I had to get under the dash on the drivers side and manually unlock it by pulling on the yellow safety tab located behind it.
    I have not come up with any other issues that i could think of after driving it around the past few days, but these are the main issues i have thus far. Any information/insight/advice would be very grateful and much appreciated.
    Thanks guys!!
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,997
    Re: Please Help....Post Engine Swap Bugs/Issues
    It seems like there's a Class II communications issue. Are you able to pull codes?
    2manyhotrods's Avatar
    2manyhotrods is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Eldorado ETC coupe.
    Jun 2013
    Massachusetts
    438
    Emergency brake not releasing and rough idle point to vacuum leak. Some hose not connected?
  5. #4
    Jan 2005
    37
    Quote Originally Posted by maeng9981 View Post
    I am not able to pull any codes from the DIC buttons, and i dont have a handheld code scanner. I will try to stop by and Advanced Auto Parts and see if they are able to pull anything and post with an update when that is complete
    Quote Originally Posted by 2manyhotrods View Post
    I checked under the hood and everything seemed to be connected, but will do some double checking just to make sure.
  6. #5
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,264
    parking brake release not vacuum operated in an 02 Seville -
    assuming nothing was done on the inside of the car -
    I suspect a couple/few GROUNDS were not re-connected -
    or something was knocked loose at the under hood fuse box -
  7. #6
    Jan 2005
    37
    Re: Post Engine Swap Bugs/Issues
    I stopped at Advanced Auto to have them pull the codes.... there was only one instance for C1246 - "Brake lining sensor open circuit message"; and the remaining nine were multiples of the codes below:
    P0300 - "Cylinder Misfire Detected Random Cylinders"
    P0449 - "Evaporative Emission Vent Valve Solenoid Malfunction"
    P0650 - "Malfunction Indicator Lamp Control Circuit Malfunction"
    I am going to assume because of the multiples, this is quite possibly from the intake gasket as i had to replace the battery tonight and it is still hard to turn over to start in addition to the rough idle/hesitation of the new motor.
    As far as the other issues, i will check the fuses and see if that helps with the DIC buttons & Speedo/Tachometer
    Quote Originally Posted by basscatt View Post
    Basscatt, you assumed correctly, as there was nothing that was done on the inside of the car
  8. #7
    rodnok01's Avatar
    Feb 2012
    NC
    6,594
    Grounds, fuses and connections first off. Way too many things to miss when putting them back together and knowing th ey were tools...
  9. Remove Advertisements
