1997 Eldorado - A/C problems
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1997 Eldorado - A/C problems in Past Cadillac Vehicle Discussion; hi i have a 1997 eldorado the ac will not turn on have recharged system , replaced both hi and ...
    ttops is offline Cadillac Owners Member
    Automobile(s): None
    Jul 2014
    None
    1
    hi i have a 1997 eldorado the ac will not turn on have recharged system , replaced both hi and low scensor and the compressor is fine , what can be my next problem to look at
    __________________________________________________ _____________________________________________
    Good afternoon, Your CF account is activated. Please update your profile to show correct information and time zone.
    Instead of resurrecting a 2.5 year old dead thread on a different car, please start your own thread on your specific problem. Thanks.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,372
    Re: 1999 cadillac eldorado - A/C Problem
    Quote Originally Posted by ttops View Post
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    68
    81,927
    Re: 1997 Eldorado - A/C problems
    Was the compressor running when you recharged the system? If not, you didn't accomplish a thing. If low on refrigerant, the PCM will disable the compressor to protect it. You must clear the low refrigerant DTC to enable it before recharging.
