No Air Conditioner - Installed new compressor - still no air
Page 1 of 2 12 LastLast
Results 1 to 15 of 29
Cadillac Seville / Cadillac Eldorado Forum Discussion, No Air Conditioner - Installed new compressor - still no air in Past Cadillac Vehicle Discussion; What next? My husband installed a new compressor after adding Freon didn't fix the problem...now he says the control panel ...
    Barbaraq Guest
    UnhappyNo Air Conditioner - Installed new compressor - still no air
    says the control panel isn't sending the signal to turn the air on, so he jerry-rigged it to be always on...please help!!! (He checked the fuses at the start)
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,722
    Pull codes as described in sticky at top of forums, links to definition also there. If you post codes someone may be able to help.
    69
    82,402
    Re: No Air Conditioner - Installed new compressor - still no air
    "Installed a new compressor"?
    The PCM will disable the compressor to prevent damage to it if low refrigerant is detected. If that was the case before the replacement, then the low refrigerant DTC must be cleared to enable the compressor.
    Did he clear any low refrigerant code?
    Did he pull a vacuum before recharging the system?
    Barbaraq Guest
    He pulled the codes but there was not any low refrigerant code and he did pull a vacuum before recharging the system.
    Jumped from pin 87 to 30 on the relay plug and the clutch kicked in but still blowing hot air
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,180
    Clogged expansion orifice ??? Replace the tube.
    Two wrenches, aluminum lines, careful. 18 lb/foot tight.
    The right cap is the high side, left is low.
    If it is clogged - no apparent flow/temperature change across the orifice - then perhaps the original compressor blew and contaminated the system. There's also a filter/dryer there - the can with sticker on top.
    bthor76's Avatar
    bthor76 is offline Cadillac Owners Member
    Automobile(s): None yet
    Jun 2014
    New Orleans
    9
    I don't think this is your problem but hopefully he replaced the orfice tube and dryer. Those two components are ALWAYS replaced when a new compressor is installed.
    69
    82,402
    Quote Originally Posted by Barbaraq View Post
    Where there any HVAC door actuator codes?
    What are the A/C pressure readings?
    Barbaraq Guest
    no a/c codes at all.
    by dryer do you mean the accumulator?
    pressure readings: 25 on low and 35 high
    69
    82,402
    Yes, the dryer is also called the accumulator.
    If those are running pressures the low side is low, but the high side is WAAAAAAY low. It should be in the 175-200 range.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,993
    You are significantly low on refrigerant.
    x2xplaguex2x is offline Cadillac Owners Member
    Automobile(s): 1997 ETC
    Sep 2012
    Texas
    33
    16
    Make sure those are running pressures, big difference your looking for 35 to 45ish on the low side and 175 to 250 on the high side depending on the temp outside
    The best way is to remove all refrigerant and fill by weight, that is the most accurate[COLOR="Silver"]
    MrMagoo565 is offline Cadillac Owners Member
    Automobile(s): 2000 SLS
    Mar 2012
    15
    I have switched to my account from my wifes...
    I have the compressor working now without hot wiriring it.
    I put a vacuum on the system and re-added coolant.
    The low side is running at around 78 the high is about 100 at idle.
    26/105 @ 2k rpm
    Outside temp 82
    Feb 2006
    57,180
    Quote Originally Posted by MrMagoo565 View Post
    At some point the CF username monitoring system may trigger a multiple username warning - if you both use the same computer/phone.
    Which username do you want to retain ?
    Your refrigerant is still low ............
  16. #14
    Mar 2012
    15
    We have separate computers that we use to sign on with.
    How do I get enough coolant in the system without over charging it?
    What should the low side be at?
  17. #15
    Feb 2006
    57,180
    As posted, the (most) accurate way is to totally vacuum evacuate the system and add the exact 2.2# of refrigerant r134a.
    He has two accounts in the same household - the MrMagoo565 one and Barbaraq.
  18. Remove Advertisements
