Service emissions and P 0174
Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Cadillac Seville / Cadillac Eldorado Forum Discussion, Service emissions and P 0174 in Past Cadillac Vehicle Discussion; Well, to keep threads on topic and off this subject and less clutter, I'll ask away on this one! So, ...
    BigPimpinCaddy's Avatar
    BigPimpinCaddy is offline Cadillac Owners Fanatic
    Automobile(s): 96 Eldo ETC, 96 Jaguar XJ6, 97 Jeep Grand Cherokee 5.2L
    Nov 2013
    Oakland, California
    238
    So, I have the "Service Emissions System" Message and PC0174.
    New PCV valve and grommet coming in, if that doesnt fix it, what do I check for and where? Pictures would be nice showing what to check.
    Thanks everyone I can't express enough how greatful I am for all the help I've been getting
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,186
    Re: Service emissions and P 0174
    For some reason you have lean fuel trim in Bank 2 - the left (front) bank. Vacuum leak or sticking fuel injector.
    File this link for future reference - it sure helps when the definitions of DTCs are posted along with the code.
    http://www.obd-codes.com/trouble_codes/gm/obd_codes.htm
    69
    82,405
    The PCV valve and grommet are on the right (rear) bank, Bank 1, so replacing the PCV valve and grommet probably won't help much. Check the vacuum lines on the left bank side.
    Nov 2013
    Oakland, California
    238
    Could I possibly see a diagram of the vacuum lines? My mechanic thinks I'm missing a line but not positive. It was night time so it wasn't really able to be checked good.
    Also - replaced valve and grommet. Code came up during a drive today.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,874
    Quote Originally Posted by BigPimpinCaddy View Post
    here ya go -
    http://lmgtfy.com/?q=1996+eldorado+vacuum+hose+diagram
    Nov 2013
    Oakland, California
    238
    Thanks I'll check it out in the morning.
    Anything else to look for besides vacuum leaks, should I do a seafoam treatment?
    Feb 2006
    57,186
    Leave the Seafoam where it is - on some store shelf. Forget the urge to pour magic potions and snake oil into the oil or gasoline.
    Google "top tier gasoline".
    69
    82,405
    No..
    Nov 2013
    Oakland, California
    238
    No..
    Thanks sub.
    Well on the website it says to check the fuel filter.
    I checked the fuel sitting in the fuel filter once. DIRTY DIRTY DIRTY. This was during fuel pump replacement.
    I checked it a few minutes ago, pretty dirty (Almost black) so I'll be replacing it tomorrow.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    It ain't the filter.
    And the filter holds the contaminants. Fuel "in" (?) the filter should not "look" dirty. Where are you looking? The filter is under the car, and not transparent...
    Feb 2006
    57,186
    Maybe the fuel he looked at was from the inlet side of the filter - in that case it could drip out some particles and dirt.
    One reason that, like my oil filters, I cut them apart and inspect the media for the type of crap trapped there.
    Nov 2013
    Oakland, California
    238
    Black gasoline actually IN the filter after removal
    Anyways I think I found my leak. After spraying carb cleaner on lines I heard a rpm raise near the TV
    So after extensive spraying finding where it's actually spraying from, I found it was here
    What is this to?
    So I actually found a rubber o ring (there was none there) that was perfect fit, tightened it up no more hiss or Rpm raise. Cleared code now let's hope it works!
    Feb 2006
    57,186
    That's the EGR exhaust gas inlet pipe. When EGR is operating, 900 degree exhaust gas flows through that pipe, thus the metal/fiber insulation sleeve.
    Because the EGR valve is just out of the picture to the right, I wonder if there's a pintle leak - that valve should allow NO exhaust gas flow except under certain engine load conditions, and at idle is not one of them.
  16. #14
    oldstuff is offline Cadillac Owners Fanatic
    Automobile(s): 66 convert-93-96-97-97-99 Eldorados
    Nov 2013
    McCleary Wa.
    81
    460
    Hope you found a mighty high temp O ring.
    Dave
  17. #15
    Nov 2013
    Oakland, California
    238
    Quote Originally Posted by Submariner409 View Post
    Hmm, well I'm going to drive her tonight and see if a code comes up.
    " that valve should allow NO exhaust gas flow except under certain engine load conditions"
    Could that be why the code would not constantly stay on and "service emissions"/ the code goes off usually after a couple restarts for short travel
  18. Remove Advertisements
