Results 1 to 13 of 13
Thread: 1991 Seville issues I just cant figure out.
    seville1991 is offline Cadillac Owners Member
    Automobile(s): 1991 seville
    Jul 2014
    44
    29
    I just bought a 1991 Seville with 84000 miles on it. When I bought it it lugged, chugged, however you want to describe it. I have changed the egr solenoid, entire distributor. Done all of the fuel injectors. What it does now. When I start it, it may run perfect or it may be off. Example: I start it this afternoon and its running great, drive 20 minutes, not problems, then all of a sudden, something will happen, and it starts chugging, it knocks a bit from the low end, O2 sensor values are all off, idle goes all screwy. Or, It could start out running crappy and then all of a sudden something happens and it starts running great.
    It needs to be stated that this car, when it is running correctly, runs perfectly, no knock, no nothing. The car does not overheat either way. I pulled the egr valve to make sure the passages are clean.
    To me it has to be a sensor that is telling the car an incorrect value. When it is running incorrectly, the only values that are really off are the idle and the O2 sensors. Fuel etc, seems to stay in specs. You just never know what you are going to get and how long its going to last. Cat not clogged, I have good acceleration either way. Timing was extremely hard to set, wandering because the car was in the running crummy mode when I set it after doing the distributor. It is something that is making the computer screw up, but what?? Thanks a ton for your time~!
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    Re: 1991 Seville issues I just cant figure out.
    Given the age and low mileage, I would locate all the engine grounds , remove them and clean them first. I would also do a load test on both the alternator and battery.
    eldoradogary is offline Cadillac Owners Fanatic
    Automobile(s): 1995 Eldorado, 2000 STS
    Jun 2012
    61
    134
    Quote Originally Posted by carnut View Post
    I agree, could be a few things at least. I would check your fuel pressure.
  5. #4
    69
    82,284
    In addition to all of the above, have you pulled the DTC?s?
  6. #5
    Jul 2014
    44
    29
    It has no codes. Sometimes it runs like a top, other times it chugs and knocks and runs like garbage. No rhyme or reason. I think they were trying to hunt this problem down before me, lots of vacuum hoses look new. I know the engine was out at some point because they worked on the transmission. The one thing I am thinking about is when I replaced the distributor, I had to transfer the old connectors to the new one, I would like to replace those, but not sure where to buy them.
  7. #6
    69
    82,284
    Check Rockauto. They have a lot of electrical connectors.
  8. #7
    lizzardman is offline Cadillac Owners Member
    Automobile(s): 92 Seville and a 74 cadillac Eldorado Convertible
    Apr 2011
    Sedona Arizona
    42
    Sounds exactly the same as when my 92 Seville computer went bad.
  9. #8
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,538
    Post one reads just like our 94 when the distributor timing was off.
    It lugged and chugged and did some knocking.
  10. #9
    Jul 2014
    44
    29
    If I purchase a computer from an auto parts store and switch the prom over, is it then plug and play or does it need to be reprogrammed for my car??
  11. #10
    nburris is offline Cadillac Owners Member
    Automobile(s): 1991 sedan seville
    Jun 2015
    25
    I also have a 1991 sedan seville with 114000 miles it starts every time and runs good it is just when I get up to 45 and it shifts into that gear it will start shaking almost hesitating but not real bad to where it stalls. My service engine light is on and I had it hooked up and a code 48 came up just wondering what I could do about these two problems especially the first
  12. #11
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,701
    Quote Originally Posted by nburris View Post
    always include DEFINITIONS along with the codes -
    no one remembers the old OBD1 codes anymore
  13. #12
    Jun 2015
    25
    I believe the code 48 is egr problem
  14. #13
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,701
    hmmmmmmmmm -
  • You may not post replies
