ccdic bd24 have anything to do with air control
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, ccdic bd24 have anything to do with air control in Past Cadillac Vehicle Discussion; On my '90 Seviile,on the BCM codes,BD24 controls 0-9 for air flow control.Does this have anything to do with why ...
    billwet80 is offline Cadillac Owners Member
    Automobile(s): 1990 seville
    Aug 2013
    15
    Coolccdic bd24 have anything to do with air control
    On my '90 Seviile,on the BCM codes,BD24 controls 0-9 for air flow control.Does this have anything to do with why my A/C only blows through the defroster.The BD24 code says it is set on #5 mode which means off but I want to know if setting it to bi-level #2 mode I think would change the way the A/C blows through the vents and how do you change the setting on the computer?I hope I explained this right.Thanks!!!
    68
    81,917
    Re: ccdic bd24 have anything to do with air control
    Defrost is the default mode and the system is vacuum controlled. Look for a vacuum leak.
    Hint:
    The parking brake auto release is on the same vacuum circuit. Start by checking the cabin vacuum supply line at the passengers side firewall. If you have vacuum there, then check the parking brake release diaphragm. If that is OK, work your way back from there.
    Aug 2013
    15
    Thanks Ranger!! Your help is much appreciated!But I was wondering if BD24 in the driver info center which is the air flow control mode that is set at #5 setting which is off can be changed somehow to the #2 setting which is the bi-level setting mode.Does this setting in the DIC have anything to do with how the air blows in the car?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,368
    Quote Originally Posted by billwet80 View Post
    I imagine you are looking at the over-rides -
    or some other settings within the OBD computer -
    you have very little control over the climate control system -
    other than temperature and fan speed -
    what ever buttons you can select from the control panel -
    is all the choices you have -
    the FSM - Factory Service Manual lists all the possible controls and possibilities -
    here is a used Factory Service Manual for $13 - including shipping -
    this is a STEAL - and you should jump on it - NOW -
    http://www.ebay.com/itm/1990-CADILLA...051e21&vxp=mtr
    Aug 2013
    15
    Thanks Basscat! I have the service manual for this car but it doesn't really tell you what is used to switch the modes in the BCM.But thanks for your help!
  8. Remove Advertisements
