Alternator question during heavy bass hits
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Like Tree1Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Alternator question during heavy bass hits in Past Cadillac Vehicle Discussion; So I have a 1600 Watt system setup on my Eldo. Pounds really hard, but I notice the voltage on ...
    BigPimpinCaddy's Avatar
    BigPimpinCaddy is offline Cadillac Owners Fanatic
    Automobile(s): 96 Eldo ETC, 96 Jaguar XJ6, 97 Jeep Grand Cherokee 5.2L
    Nov 2013
    Oakland, California
    238
    Pounds really hard, but I notice the voltage on the readouts will read as low as 11.8 during heavy bass hits.
    Alternator usually puts out 13.4-13.8 volts while driving without music.
    Is there a way to prevent these low of a drops during hard heavy bass hits? Will a capacitor help?
    Or should I just upgrade my alternator -- thanks everyone!
    http://www.dbelectrical.com/p-9464-a...-eldorado.aspx
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,538
    Re: Alternator question during heavy bass hits
    Most say caps are most efficient at draining your wallet not fixing your issue.
    Adding a second battery (Or more) usually helps and has other benefits.
    Many say a high output alt is the only real fix.
    Look at any serious bass head build you will find a battery bank and a high output alt (or several).
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,121
    Without music, engine running above idle, your DIC voltage - and voltage measured with a DVM - should show between 14.2 to 14.8 volts.
    Looks like your present alternator is not up to capacity. Electrical connections, deteriorated terminals, marginal battery - lots to check and make right before throwing more parts at it.
    The battery is the reservoir that should supply the amperage necessary to deliver bass punches. The alternator refills the battery. If the alternator is not operating at its best efficiency then neither is the battery.
    carnut likes this.
    Nov 2013
    Oakland, California
    238
    Thanks amunderdog, great info.
    Thanks Sub, always with the helpful descriptive information. I guess it's new alternator time. Music off, DIC Voltage got as low as 13.3 idling at a red light. Driving at about 1200-1500 rpms it would be at around 13.4-13.6, Startup it's at 14.1-14.2.
    Paying for a higher amperage alternator wouldn't do much? So should I go with this Ac Delco unit? http://www.rockauto.com/catalog/more...571&cc=1026278
    Terminals have been replaced, battery is not that old (will add electrolytes and bring it up to par), connections check ok.
    Just debating which alternator to get (and visioning what a PITA it will be to get the old one out, lol)
    Or is this cheaper $50 alternator just fine?
    http://www.rockauto.com/catalog/more...350&cc=1026278
    I'm thinking ACDelco though.
    Feb 2006
    57,121
    If your original alternator is the 140 amp unit, that big AC Delco is the one you want.
    Your present running voltages look to be about 0.6 to 0.8 volt low.
    If you want to doodle away a half hour with a scotch & water, Google "automotive 12 volt battery charging theory".
    Feb 2010
    Sunbright, TN
    1,538
    http://www.stevemeadedesigns.com/board/
    http://www.mechman.com/alternators/c...ado/93-02/4-6/
    You have your amp in the trunk? With wiring pulled to it? 0 gauge at least?
    If yes to the above then I would add a sealed gel battery in the trunk (Sears sells a real nice one I hear) and see if things improve.
    Feb 2006
    57,121
    He needs to supply POWER to the battery(s) first. More batteries don't mean squat if you can't keep them charged.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,845
    Quote Originally Posted by BigPimpinCaddy View Post
    Just debating which alternator to get -
    you are correct - it is NOT a fun job -
    with that in mind - you do NOT want to replace it very often -
    so I would agree with the new ACDelco unit you listed -
    HOWEVER -
    I can save you some money - over $50 in fact -
    rather than paying rock auto $157 - with shipping -
    amazon sells the same unit for $103 - with free shipping -
    http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
    you are welcome -
    Nov 2013
    Oakland, California
    238
    Sweet. I'll get right on it, Thanks!
    Nov 2013
    Oakland, California
    238
    So, I refilled my battery with electrolites. Stronger 12.1 Volts and holding a good charge.
    I added in a capacitor I had lying around. Voltage went as low as 12.8 in the driveway (I just turned the car on to test it out) SO we'll see how a drive goes.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Is 12.1 battery or charging voltage?
    Nov 2013
    Oakland, California
    238
    Battery
    Oh god that alternator would be thrown out instantly if it was charging at 12.1 lmao.
    Sep 2010
    East Boston MA.
    29
    26,323
    A healthy battery puts out 12.6 volts, 12.0 is dead. 12.1 is at the end of its life.
  16. #14
    Feb 2006
    57,121
    An alternator/voltage regulator, operating normally above idle, will always put out at least 14 to 14.8 volts.
    Disconnected
    battery, untouched for a half hour .........
  17. #15
    Nov 2013
    Oakland, California
    238
    Well, driving today I am deciding to get a better battery and a new alternator.
    No music, headlights on, idling at a traffic light 12.8 volts, 13.0 driving with lights on
    So, any instructions on alternator removal? Maybe both through the bottom and radiator removal way in case I can't through the bottom.
  18. Remove Advertisements
