Seville brake upgrade (JL9) - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Like Tree7Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Seville brake upgrade (JL9) in Past Cadillac Vehicle Discussion; These look just like the brakes on my 02 STS , build date 12/01, checked RPO code yep it has ...
  1. #16
    RVMAN's Avatar
    RVMAN is offline Cadillac Owners Fanatic
    Automobile(s): 02 Seville STS
    May 2014
    FL AL GA TRI-STATES
    292
    Re: Seville brake upgrade (JL9)
    checked RPO code yep it has JL9 brakes.
  2. #17
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    JL9 basically means standard brakes with ABS. Jl9 for the Seville were single piston calipers, slightly smaller rotors (pictured on the previous page) There was no optional larger brake option (which would have been RPO CODE JE5).
    The dual piston caliper/larger rotor setup I installed is JL9 on other models, but not the Seville. If you have a dual piston setup, it's not stock.
  3. #18
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,872
    Im thinking of switching over to those rotors and pads also
  5. #19
    Sep 2010
    East Boston MA.
    29
    26,325
    The Seville and Eldo got bigger brakes in '97. I think yours would be the same part numbers as my first set.
    http://www.placeforbrakes.com/produc...&car_year=1997
  6. #20
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,872
    Thanks for the link, i really need to repaint my calipers, theyre barely 2 yrs old if even that and are rusted already
  7. #21
    Sep 2010
    East Boston MA.
    29
    26,325
    The paint that comes on them from most aftermarket brake part manufacturers/remanufacturers is pretty poor. A dedicated caliper paint, designed to hold up to the heat and environment of a caliper, will last much longer. I find it easier, overall, to remove the calipers for paint. Clean them, sand them, and clean them again. Hang them by some wire and follow the instructions on the can. Should last several years. ----------
    Half assed painting setup using a broom a neighbor threw out:
    It was way too low to the ground, so I ended up having to lift it to get to every part.
    Came out nice though:
    vincentm likes this.
  8. #22
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,368
    now it needs a little PINSTRIPING -
    vincentm and MoistCabbage like this.
  9. #23
    Sep 2010
    East Boston MA.
    29
    26,325
    Haha. Actually, I found a really nice set of caliper covers. Flat black, with white "Cadillac" script for the fronts, "STS" script for the rears. You really would't be able to see them through my rims though.
  10. Remove Advertisements
