96 Eldorado trans issues
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Aztec ETC ECS
Cadillac Seville / Cadillac Eldorado Forum Discussion, 96 Eldorado trans issues in Past Cadillac Vehicle Discussion; Hello, I recently bought a 96 Eldorado for 200 dollars knowing it had trans issues. I have the same ole ...
    Crabtree is offline Cadillac Owners Member
    Automobile(s): 1996 Eldorado
    May 2014
    42
    3
    Hello, I recently bought a 96 Eldorado for 200 dollars knowing it had trans issues. I have the same ole problem most everybody else has with the car not upshifting into O/D the car will not travel faster than 40 mph and if you stay on the fuel the rpm's go up but not speed. I bought the shift solenoids from Cadillac for 84 dollars and had a dealer install for 188.40. One solenoid was broken but the car still wont go above 40. Traction control light is on as well. All other gears work and fluid is clean and full. Any Ideas? Thanks everyone.
    johnny kannapo's Avatar
    johnny kannapo is offline Cadillac Owners Connoisseur
    Oct 2009
    Pigseye, Mn
    56
    2,814
    Re: 96 Eldorado trans issues
    The car shifts into OD around 45 mph at cruising speeds. The dealer would be the one to shed light on the defects. The traction light is a related problem, it can and will limit performance although may or may not be related to the trans. You say "dealer" is this a GM or Cadillac dealer? You need a proper diagnostics check and you can do this your self right on the dash board sitting in the driver seat. the car will tell you everything, no other equipment needed. Look at the sticky on the top of the seville/eldo forum page and stick your nose to the screen.It will give you current & history defect codes and then find the definitions and then get back and folks here can help you sort things out.
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    Quote Originally Posted by Crabtree View Post
    Same ole broken band. Nothing else.
    maeng9981 likes this.
    May 2014
    42
    3
    what band may be broken?
    Ran through the codes. Here is what came up.
    PC0636
    PC0603
    PC1406
    PC0741
    PC1644
    PC1111
    PZ1970
    PZ2471
    PZ2473
    PZ2476
    PZ2042
    PZ2056
    PZ2152
    PZ2255
    PZ1558
    PZ2470
    IR1740
    IR2064
    IR2255
    TC0073 CURRENT
    Any ideas?
    Also, it was not a GM dealer that installed the solenoids, it was the only thing available.. Suzuki. Please dont laugh, it was my best option. LOL
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,846
    PC0636
    PC0603
    PC1406
    PC0741
    PC1644
    PC1111
    PZ1970
    PZ2471
    PZ2473
    PZ2476
    PZ2042
    PZ2056
    PZ2152
    PZ2255
    PZ1558
    PZ2470
    IR1740
    IR2064
    IR2255
    TC0073 CURRENT
    Any ideas?
    codes are just meaningless letters and numbers
    without their DEFINITIONS -
    Feb 2012
    NYC
    50
    1,948
    No OD=broken/burnt OD band.
    Not "may be" either.
    A bad or broken solenoid will always & only result in the loss of 2(two) gears.
  9. Remove Advertisements
