1977 Eldo Steering Wheel removal?
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1977 Eldo Steering Wheel removal? in Past Cadillac Vehicle Discussion; I have a 1977 Eldorado. I have to replace the ignition and door lock cylinders. I realize I have to ...
    Absolut_X is offline Cadillac Owners Member
    Sep 2005
    I have a 1977 Eldorado. I have to replace the ignition and door lock cylinders. I realize I have to remove the steering wheel for the ignition cylinder. When i remvoe the pad and horn wire & the telescoping screws... how do I remove the rest? I have a Chilton's manual, but don't seem to be able to remove the "plate assembly" for the telescoping mechanism. I've attached some images of what I'm referring to.
    crapname is offline Cadillac Owners Member
    Automobile(s): '88 Seville
    Apr 2010
    1
    Re: 1977 Eldo Steering Wheel removal?
    I know that this post is years old, but I found it while searching for the same thing myself on my '88 cadillac seville (It has the exact same telescopic ring thingy). The way to remove it I found (after trying to pull it off only to bend it up pretty bad), is just to grasp it with a pair of pliers and unscrew it counter-clockwise.
    Maybe this'll be helpful to someone else who comes along in 4 or 5 years, lol.
    Rich59 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Dec 2007
    4
    I use a screwdriver in the elongated slot. Just turn the driver it will come right out.
    camscaddy is offline Cadillac Owners Member
    Automobile(s): 1976 Baritz
    May 2012
    57
    Yes thats the way to do it and gere's proof it works.
    Off with the spilt wornout wheel
  7. Remove Advertisements
