2000 STS position sensors ?
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2000 STS position sensors ? in Past Cadillac Vehicle Discussion; where i can i buy a position sensor please...
    david.m is offline Cadillac Owners Member
    Automobile(s): seville sts 2000
    May 2014
    3
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,857
    Re: Service Suspension System?
    Quote Originally Posted by david.m View Post
    start with ROCKAUTO.COM
    May 2014
    3
    thanks , but which one would it be im confused
    Alignment Shim
    Ball Joint
    Caster / Camber Cam Bolt Kit
    Coil Spring
    Coil Spring Insulator
    Coil Spring Seat
    Control Arm
    Control Arm Bushing
    Lateral Link
    Rear Suspension Toe Link
    Self-Leveling Unit Sensor
    Shock Absorber
    Shock Absorber Air Hose Kit
    Shock Absorber Conversion Kit
    Shock Mount
    Stabilizer Bar Link
    Strut
    Strut & Mount Kit
    Strut / Coil Spring / Mount Assembly
    Strut Bearing
    Strut Bellow
    Strut Mount
    Strut Mounting Hardware
    Track Bar
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Self leveling unit sensor.
    I would check if the connecting rod between the sensor and control arm is present and connected first.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,857
    so - WHY do you think you need one -
    do you have DTC's - fault codes?
    if yes - post the codes along with the definitions -
    May 2014
    3
    Re: 2000 STS position sensors ?
    yes, my mechanic says i have to buy one . DTC C0630 Right Rear Position Sensor Malfunction
    do you have a link where i can see how to check that please
    Sep 2010
    East Boston MA.
    29
    26,323
    I do not. Just look in the wheel well (it's easier with the wheel off). The sensor is mounted to the body. The connecting rid should be connected to the arm of the sensor, and to the lower control arm.
    69
    82,386
    This help any?
  11. Remove Advertisements
