Results 1 to 12 of 12
Thread: 96 Seville Theft Deterrent Problem
    fmw63 is offline Cadillac Owners Member
    Automobile(s): 1992 Seville
    Nov 2003
    Hyattsville, MD
    39
    After car wouldn't start because of bad battery one night, replaced battery, but all it will do is crank - not start.
    The DIC shows Theft Deterrent message. Had car towed to a local Chevy dealer (the Cadillac dealer was booked for the
    whole next week). They determined (incorrectly) that the problem was the ignition lock cylinder. Actually it was bad,
    but had already done the VATS bypass. They changed the lock cylinder and keys, and supposedly reprogrammed it, but
    still won't start. Before, the code was a P1631. Now when I check codes, there are several: IP1552, PC1631, PC1632, IP2750, and an SD1026. But the thing is, all are history - no current codes. I've installed the Newrockies Pro module to bypass this system, but that hasn't worked either. Neither has doing the 10/10/10 relearn procedure. Is it
    now just a matter of changing parts (PCM or IPC) and trying again? Really can't afford hours and hours of dealer diag time plus parts right now...
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    VATS disables the fuel pump and starter, so that's not the issue.
    Post the code definitions, they're meaningless without them.
    Fuel pump running? Spark?
    Nov 2003
    Hyattsville, MD
    39
    Re: 96 Seville Theft Deterrent Problem
    Oh yeah, forgot. fuel pump & spark ok (says Pep Boys).
    codes:
    DTC P1631 Theft Deterrent Start Enable Signal Not Correct
    DTC P1632 Theft Deterrent Fuel Disable Signal Received
    DTC B2750 PASSKey Data Communication Failure
    IP1552 = Loss of KAM
    but all are history, no current codes
  5. #4
    Nov 2003
    Hyattsville, MD
    39
    help! anybody?
  6. #5
    Sep 2010
    East Boston MA.
    29
    26,323
    Was the fuel pressure checked, or did they just check that the pump was running.
    You fuel and spark, something should be happening.
  7. #6
    Nov 2003
    Hyattsville, MD
    39
    They did check fuel pressure, was ok. "starting disabled" theft deterrent message still there, but no current codes
  8. #7
    Nov 2003
    Hyattsville, MD
    39
    Need some help here guys!
  9. #8
    oldstuff is offline Cadillac Owners Fanatic
    Automobile(s): 66 convert-93-96-97-97-99 Eldorados
    Nov 2013
    McCleary Wa.
    81
    460
    Sounds very much like the situation I had. Theft deterent message, Had fuel pressure, Starter would spin the engine but no start, no codes. Turned out to be a ground wire off at the passenger end of the transmission.
    Dave
    Quote Originally Posted by fmw63 View Post
  10. #9
    Sep 2010
    East Boston MA.
    29
    26,323
    What kind of "bypass" is this Newrockies thing? If VATS is fully disabled, the message shouldn't display. And if it does display, the starter and fuel pump shouldn't be working. If someone played with the VATS system, other electrical issues could be causing the no start condition.
  11. #10
    Nov 2003
    Hyattsville, MD
    39
    Guess I have to check some wires, then. Thanks for the idea.
  12. #11
    fltdriver is offline Cadillac Owners Fanatic
    Automobile(s): 1999 ELdorado
    Feb 2014
    137
    Your TDM could be bad. (Theft Deterrent Module)
  13. #12
    Nov 2003
    Hyattsville, MD
    39
    checked cables again. seemed ok there. battery needed a jump - was getting run down. left it charging while checking for codes and doing relearn procedure again. Now getting some current codes finally: IP2750 PASS-KEY II Data Communication Failure and a PZ1558 BCM EPROM Checksum Error.
    Is this looking like a bad bcm?
  • You may not post replies
