ABS Orange light and Traction Control Disabled after rear pad install
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Cadillac Seville / Cadillac Eldorado Forum Discussion, ABS Orange light and Traction Control Disabled after rear pad install in Past Cadillac Vehicle Discussion; my 94 Eldo with 73000 miles had worn rear pads, down to about 1/16th inch, no metal to metal, but ...
    Northstarnut's Avatar
    Northstarnut is offline Cadillac Owners Member
    Automobile(s): Eldorado
    Oct 2013
    Granite Falls, WA
    64
    20
    my 94 Eldo with 73000 miles had worn rear pads, down to about 1/16th inch, no metal to metal, but I replaced the pads anyway. I opened the bleeder valves and somehow air got inside, so I have tried twice to bleed them. Though I am pumping 2-3 times with fluid out, the M/C does not take any fluid. When I start the car the pedal goes down, but without the engine on the pedal is hard with short travel. The ABS orange light stays one and the panel says traction is disabled. There were no lights or problems before the pad replacement, so I have to assume it is air in the system, but if it won't take new fluid in, how do I get it to bleed? I only did the rear pads...so the front brakes should be without air. HELP?
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Re: ABS Orange light and Traction Control Disabled after rear pad install
    Look at the rear wheels (the hubs), in the back there is a connector, you most likely unplugged the ABS speed sensor in the process of replacing the brake pads. Also just so you don't have to pull both wheels to see which one is it, you can pull your codes (is all available from the buttons on the dashboard, no need to go to mechanic or use any scanner, check the sticky "How to pull codes" for instructions). Write down the codes and use the links provided with the instructions (remember your car is OBDI) to see what the codes mean. Will be something like "LR wheel speed sensor...".
    Lesson learned, plug back all connectors when you are done with the repair
    The vehicle will not show any codes if you have air into the brake line (there is no monitoring for that).
    Feb 2003
    california
    69
    6,680
    No longer you Fathers Cadillac is it!
    69
    82,163
    Are you sure you bled the system properly. Hard to tell from your description.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,565
    Quote Originally Posted by Northstarnut View Post
    I don't understand what you are saying -
    post EXACTLY how you are bleeding the rear brakes -
    and are you bleeding them by yourself -
    Oct 2013
    Granite Falls, WA
    64
    20
    I have the one-way valve for doing it myself. I have pumped fluid/air out and tightened the bleeders again but when I go to the master cylinder to top it up it is already full still. I started with the right rear and then the left. The fronts should not have been affected. They pump up hard when the engine is off. Since the ABS light is a separate issue I may have them bled correctly. I thought because the light was on, I still had not done it right, but since there is no light indication or code for air in the lines, I will work through it today and take a test drive.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,565
    can't be -
    IF you are actually pumping any fluid out -
    the master would be low -
    that proves nothing -
    you must have the engine running to bleed the brakes -
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    I never run the engine while bleeding the brakes. You just have to force fluid out of open lines, you definitely don't need the booster for that.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,565
    the OP is using one-way bleeders -
    I believe he is not getting any fluid out -
    because there isn't enough pressure being developed without the booster -
    Sep 2010
    East Boston MA.
    29
    26,325
    Oh ok, that changes things.
    69
    82,163
    I agree. If the fluid in the MC is not going down, you're not bleeding anything.
    Sep 2010
    East Boston MA.
    29
    26,325
    Where is the reservoir you're looking in located?
    Oct 2013
    Granite Falls, WA
    64
    20
    Quote Originally Posted by N*Caddy View Post
    You got it dead right. I found the loose plug on the right rear and now no codes or messages...Thank you! I would never have seen it, it was so well hidden!
    Nope and I would prefer the old ways on things like hydraulic brakes! I am smart enough and a high performance enough driver to never need ABS. It was designed by Congress for idiot low performance drivers!
    Quote Originally Posted by carnut View Post
    Yes I am pretty smart and experienced in this...unless there is something in the system that prevents it.
    Yes all by myself and 45 years of experience
    I got plenty of rusty fluid out, 3 pumps worth
    UHhh...on the brake booster
  16. #14
    johnny kannapo's Avatar
    johnny kannapo is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Eldorado
    Oct 2009
    Pigseye, Mn
    56
    2,814
    Pumps & bleeders are a lot of fooling around. Get a piece of vinyl hose on the nipple and gravity bleed them. Do a google search or otherwise for "gravity bleeding" and look at images & read. This is too simple. Too easy......
  17. #15
    69
    82,163
    I've never had any luck with the gravity method. Slower than molasses in January.
  18. Remove Advertisements
