93 STS idles poorly
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, 93 STS idles poorly in Past Cadillac Vehicle Discussion; I've been working on a 93 Seville (with a friend) and finally have it on the road, it drives pretty ...
    SEATTLEBOI18's Avatar
    SEATTLEBOI18 is offline Cadillac Owners Member
    Automobile(s): 1993 Seville sls
    May 2014
    Belfair
    1
    Post93 STS idles poorly
    I've been working on a 93 Seville (with a friend) and finally have it on the road, it drives pretty good but idols rough at low rpms.
    Also there is a weird fate high pitch sound when I press on the gas pedal and I can smell the gas its not a bad strong smell but noticeable. The RPM needle is never steady, I don't know jack about cars so if you could explain it to me like I'm 7 that would be great. It has about 135,000 miles on it.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,466
    Re: 93 seville sls idols bad
    Quote Originally Posted by SEATTLEBOI18 View Post
    probably a vacuum leak -
    would explain the sound -
    and at least part of - if not the sole cause of - the rough idle -
    obviously a gas leak -
    every piece of rubber could be over 20 years old -
    and has dried - and become brittle - with cracks all over it -
    inspect and replace as needed ALL rubber hoses -
    that would be great
    gasoline burns -
    gas fumes EXPLODE -
    if gasoline is leaking onto a hot motor -
    it quickly turns to gas fumes = BOOM -
    don't screw around with gas leaks -
    a gas fire can QUICKLY get out of control -
    do NOT keep the car in a gargae -
    until the gas leak is found - and repaired -
    68
    82,048
    Re: 93 STS idles poorly
    Check the intake manifold cover. It could be leaking at any point around the perimeter. Spray some Brakleen or TB cleaner around it at idle. If you get an RPM increase, you've found the leak.
    P.S.
    If that is the problem, be sure to use a torque wrench and the proper torque setting when reinstalling it.
    P.P.S.
    While you are at it, the FPR is inside the manifold and might account for your fuel smell. See the Tech Tips section for a tutorial on checking it.
    Pay particular attention to the note pertaining to the '93/'94.
