7/8” replacement sway bar bushings for the 92- 02 Eldorado / 92-97 Seville?
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, 7/8” replacement sway bar bushings for the 92- 02 Eldorado / 92-97 Seville? in Past Cadillac Vehicle Discussion; ...
    CadVetteStang's Avatar
    CadVetteStang is offline Cadillac Owners Fanatic
    Automobile(s): 2002 Eldorado ESC, 70 Eldorado, 82 Eldorado w/472
    Apr 2008
    Little Rock, Arkansas
    51
    150
    Question7/8” replacement sway bar bushings for the 92- 02 Eldorado / 92-97 Seville?
    I can find rubber replacement bushings for the 19MM and 21MM bars, but I found a rare OEM 7/8” front bar. I am looking for polyurethane bushings for it. Any known suppliers or will I have to make a mold and produce my own?
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,593
    Re: 7/8” replacement sway bar bushings for the 92- 02 Eldorado / 92-97 Seville?
    If your bushing look like this post then try energy suspension 22MM bushing set.
    http://www.cadillacforums.com/forums...ings-98-a.html
    Apr 2008
    51
    150
    thanks... But the outside shape is made to fit a pocket in the frame and the inside shape has a custom wedge. The 98 up Seville is a whole different car. ( but I was able to use the rear rotors and caliper brackets off of one, so nice try. I wish it would have worked. I may have to squeeze the 21mm rubber bushings around it. Maybe white lithium greace will keep it quiet for a while..... But I will have to make sure that won't break down the rubber.
