Rear Spring removal & install questions 93-02 Eldorado / 93-97 Seville
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, Rear Spring removal & install questions 93-02 Eldorado / 93-97 Seville in Past Cadillac Vehicle Discussion; I am preparing to install the racing springs in my 02 Eldorado. 1. Can the springs be removed safely without ...
    CadVetteStang's Avatar
    CadVetteStang is offline Cadillac Owners Fanatic
    Automobile(s): 2002 Eldorado ESC, 70 Eldorado, 82 Eldorado w/472
    Apr 2008
    Little Rock, Arkansas
    51
    150
    QuestionRear Spring removal & install questions 93-02 Eldorado / 93-97 Seville
    1. Can the springs be removed safely without compressors like the front coils on most RWD cars using a floor jack? My concern is the bend that the springs have when the lower arms are fully extended.
    2. If so, can the replacement springs be installed in the reverse manor? They will be a little shorter, but almost as stiff a little over 520 pounds instead of the stock 275
    3.Is there a trick to bending the springs for this installation?[/SIZE]
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Yes.
    Yes.
    Slowly.
    Apr 2008
    51
    150
    Re: Rear Spring removal & install questions 93-02 Eldorado / 93-97 Seville
    Cool. I pulled the replacement springs from the donor car at the salvage yard today between jobs. It took an hour and a half. At current length they are 489 lbs. / inch. Depending on how much I cut them, they should be between 525 and 575 .I will then adapt SVT Cobra shocks to get them tamed.
