2001 Eldorado stall issues as it warms up
Results 1 to 10 of 10
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2001 Eldorado stall issues as it warms up in Past Cadillac Vehicle Discussion; My uncle has a 2001 El Dorado when he starts up the car if he sits in it and talks ...
    dantemoravil's Avatar
    dantemoravil is offline Cadillac Owners Fanatic
    Automobile(s): Devilles: 04 Base,01 base,01 DHS,92 (parents)
    Nov 2011
    Cincinnati, Ohio
    51
    211
    My uncle has a 2001 El Dorado when he starts up the car if he sits in it and talks to me for six minutes it will stall out and then not start. he moves it into neutral and it will start right up. Another symptom is while he's driving it will occasionally stall out when he's going downhill.
    My initial thoughts is he has a short somewhere in his system on the positive side because occasionally he also has to reset the radio stations and Clock etc.
    I don't see my uncle all the time so I can't help him quickly he lives 55 minutes from me.
    Am I on the right track or my barking up the wrong tree?
    Thanks ahead of time for any comments I do appreciate it
    Oh I forgot when he was at my house on Easter it does have service engine light but he wasn't there long enough for me to figure out what codes he has.
    And the other thought I had is that it has to do with the antitheft system and I'm worried I might have to Teat apart the steering column.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,822
    Re: 2001 eldorado issues when it gets warm
    You need to use the sticky post just above this - "How to pull codes" - to see if there's a diagnostic code stored in the car's built-in reader/scanner.
    The symptoms sound like a CKP fault. CKP ??? Read the sticky post "Acronyms".
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,685
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    Feb 2006
    56,822
    I think I posted that - #2.
    Somebody has their view preferences set to "view oldest post first" so you never see what has been posted after the OP.
    69
    82,266
    Sounds a lot like bad CKP sensors. GM had a bad supplier from 2000-2003. Always replace both of them.
    Nov 2011
    Cincinnati, Ohio
    51
    211
    My uncle called me today and we talked about his possible crankshaft position sensor replacement to confirm what his shop told him. I told my uncle I might be able to do it but he was going to have his mechanic do it anyway. I'll let you guys know how it turns out. I appreciate your help to confirm what his mechanic told him so that my uncle would not be taken to the cleaners.
    His mechanic verbally quoted 300 to 350 for the job. Don't know if that was for both sensors or just one.
    My uncle also told me today that his mechanic has the same 2001 El Dorado and the same color and had already done that fix a couple years ago.
    Thank you all.
    Mike
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,685
    Quote Originally Posted by dantemoravil View Post
    Thank you all.
    Mike
    ALWAYS replace BOTH sensors -
    and ONLY use ACDelco parts -
    CKP - Crankshaft Position Sensors -
    ACDelco 213-1578 - $35.99 - with free shipping -
    from amazon.com -
    and -
    ACDelco 213-1579 - $39.95 - with free shipping -
    also from amazon.com
    Nov 2011
    Cincinnati, Ohio
    51
    211
    I will call my uncle and make sure he follows my instructions. Although he is 80 years old.
    I meant your instructions. Thank you.
    69
    82,266
    That doesn't sound too bad. I think a dealer price is $400-$450.
    Nov 2011
    Cincinnati, Ohio
    51
    211
    Talked to my uncle yesterday. The advice you gave me was PERFECT. Exactly what was wrong with his car. Thank you all for helping me diagnose the problem. And me giving him the information helped him feel very comfortable talking to his mechanic about it.
    Thank you all!!
    Mike
  13. Remove Advertisements
