Lean 4100
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, Lean 4100 in Past Cadillac Vehicle Discussion; Searching "4100 lean", I came across this forum, and you guys seem to be very knowledgeable, maybe you can help ...
    tmd171 is offline Cadillac Owners Member
    Automobile(s): '85 Eldo convertible
    Apr 2014
    detroit
    Lean 4100
    Searching "4100 lean", I came across this forum, and you guys seem to be very knowledgeable, maybe you can help me; my '85 Eldo has no codes, starts,idles and runs pretty well but behaves lean (intermittent needs additional pedal to keep smooth acceleration)after open loop. Already changed O2 sensor, readings jump b/t .2 and .8 at steady rpm (normal?), econ light shows balanced off/on in diagnostic (indicates proper mixture?), but i know the new reformulated gasoline has necessitated richer mixtures in my other old cars. I'm tempted to alter the o2 reading w/resistors to richen things up. unless someone here knows a better way?
    Thanks, Tom
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    Re: Lean 4100
    What's the fuel pressure? I think you have either a weak pump or the filter (sock) on the in tank pump is plugged up. This car runs with low pressure so if its below minimum it will be too lean. Your Oxy sensor seems to be working normally.
    Apr 2014
    detroit
    Re: Lean 4100
    Seems to me it was 10-12psi last time I checked...I'll check it again after I pick up the gauge. I did notice the throttle body shaft has a fair amount of play in it...could this be an issue?
