Multi Disk Error
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, Multi Disk Error in Past Cadillac Vehicle Discussion; Hi all, I tried the 6 CD changer for the fist time today on my 2000 STS after it initializes ...
    jameslaz's Avatar
    jameslaz is offline Cadillac Owners Member
    Automobile(s): 2000 Cadillac Seville STS
    Mar 2014
    Phoenix, AZ
    53
    38
    Multi Disk Error
    Hi all,
    I tried the 6 CD changer for the fist time today on my 2000 STS after it initializes and I try to play a CD I get the error "Multi Disk Error" any ideas on why this is?
    I tried all 6 CDs and they were all standard CDs not MP3 disk or recordable CDs.
    Thanks,
    James
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,250
    Re: Multi Disk Error
    Quote Originally Posted by jameslaz View Post
    Hi all,
    Thanks,
    James
    make sure you put the discs in the correct way -
    and the door is fully closed -
    jameslaz's Avatar
    Mar 2014
    Phoenix, AZ
    53
    38
    I guess I could have put them in upside down. I will try the other way tomorrow. Thanks.
  5. #4
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,518
    .......... and eject the disk cassette, close the door, then fully insert it again. Once in a while this clears the "source not found" icon on the HU.
  6. #5
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    I don't know what causes them to fail but I found a cheap one on Ebay
  7. #6
    jameslaz's Avatar
    Mar 2014
    Phoenix, AZ
    53
    38
    Just an update and correction. I tried the CDs both ways still getting the error. My mistake the error actually reads "CD CHANGER ERROR".
    Thanks for the replies,
    James
  8. #7
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,250
    James
    that changes things -
    there are only 2 screws that retain the changer in the console -
    remove the screws - pull the unit out - un-plug the unit -
    turn the ignition ON - play the radio for a couple minutes -
    turn the ignition OFF - plug the changer in - turn the ignition ON -
    try the CD changer again -
    if you get the same error - post the MODEL NUMBER here -
    there was a dramatic change in the electronics in 2002 -
    a 2002 or newer CD changer will NOT work in a 2001 and older car -
    only CD changers originally from a Cadillac Deville or Seville will work -
    even though they all LOOK identical -
    units from other GM cars will NOT work in a Deville or Seville -
  9. Remove Advertisements
