Should I Put Monroe Strut??
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 37
Like Tree3Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Should I Put Monroe Strut?? in Past Cadillac Vehicle Discussion; Hey wassup people i just wanted to know if i should put a monroe front strut on my cadillac seville ...
    CadillacRider is offline Cadillac Owners Member
    Automobile(s): Cadillac Seville Sts
    Apr 2014
    27
    3
    Hey wassup people i just wanted to know if i should put a monroe front strut on my cadillac seville sts 2002 i heard they are cheaper but whats the difference between the original ones i have now
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,350
    Re: Should I Put Monroe Strut??
    Quote Originally Posted by CadillacRider View Post
    Hey wassup people
    ah - good afternoon -
    front struts must be replaced in pairs -
    so - you are now asking whether or not to replace your original struts
    with Monroe units -
    Monroe are EXCELLENT struts - and and a GREAT choice -
    THAT all depends on the build-date of your STS -
    you COULD have the F45 - CVRSS ACTIVE suspension system -
    OR you COULD have the F55 - MagnaRide ACTIVE suspension -
    Monroe does NOT make an ACTIVE strut for your car anymore -
    strictly PASSIVE units - same strut used on the SLS model Seville
    the correct Monroe PASSIVE strut for your car is the-
    MONROE 71684 - $62.35 each -
    http://www.partsgeek.com/jzhsgdr-cad...bly.html?fp=pp
    the only source for new F45 struts is ACDelco -
    they can be purchased for around $600 each -
    the F55 struts are a little cheaper -
    but also only available through ACDelco - around $550 each -
    Apr 2014
    27
    3
    So do you reccomend me putting monroe struts will it turn on any lights on my cadillac or everything is going to be ok ? Does it harm the cadillac? And should i replace all of them or just the front
    Quote Originally Posted by basscatt View Post
    Hey wassup people
    with Monroe units -
    Does it?
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    Are the old struts worn out? If they are, the new passive struts will give u a stiffer ride. Which you may like. Or not. Any new struts should make the car ride better. The issue of codes is another thing.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,350
    Does it?
    SURE - if your struts are worn out -
    and you don't want to put out the BIG BUCKS for active units -
    this is an EXCELLENT CHOICE -
    not exactly - but going PASSIVE will trigger a WARNING in the DIC -
    "SERVICE SUSPENSION SYSTEM" -
    BUT there is a cheap and easy solution -
    add resistors to "fool" the suspension computer -
    after installing the resistors - YES -
    NO -
    the rear shocks are even cheaper than the front struts -
    and would be a good idea -
    the Monroe MA822 KIT is a perfect match to Monroe front struts -
    the best price is $58.35 for BOTH rear shocks -
    http://www.partsgeek.com/32syvb4-bui...ber.html?fp=pp
    YES - the listing says it's for a Buick -
    LOTS of front wheel drive - full size GM cars use them -
    Aug 2007
    mpls mn
    2,528
    Replacing F55 struts with passive struts should be against the law since you cannot realistically add it to a car
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    We should start an SLS exchange program .
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,350
    Quote Originally Posted by stoveguyy View Post
    I have no idea WHAT that could possibly mean -
    EcSTSatic and ben.gators like this.
    Jjc4908 is offline Cadillac Owners Member
    Automobile(s): 2002 STS White diamond/black interior
    Feb 2014
    Chicago, IL
    33
    46
    I just got my 02 Sts back from the shop and took basscats advice. The monroe struts ride like a DREAM!! I purchased the vehicle with the rears modified to passive on an f55. The dealership told me I needed struts for the low volume groaning I was experiencing when goin over small bumps. I replaced Both front and rears with his suggestion and I couldn't be happier. Car rides amazing and sits at the perfect height. Resistors worked well and no errors in DIC to speak of. THANKS BASS!! A fraction of the cost and a hell of a difference in ride quality.
    basscatt likes this.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,350
    Quote Originally Posted by Jjc4908 View Post
    glad you are happy with the suggestion -
    centaur's Avatar
    centaur is offline Cadillac Owners Fanatic
    Automobile(s): 2002 STS, 2005 CTS 3.6
    Aug 2006
    Alberta. Canada
    411
    Hey Basscat, my question is...what happens to the rear ride height when this conversion is done? Is it adjustable? I see alot of STSs that have obviously been converted to passive with rear ends sitting like some jacked up, old Camaro. Any ideas?
    Sep 2010
    East Boston MA.
    29
    26,325
    Passive/active refers to the damping (stiffness) of the shocks/struts, nothing to do with ELC (Electronic Leveling Control). The MA822 shocks are ELC compatible. They have an air bladder, and the stock ELC tubing plugs right into them. Ride height/leveling is unaffected.
    If the rear is jacked up, it means the ELC system isn't exhausting. Usually that means a faulty exhaust solenoid. If its sitting on the ground, the elf system isn't functional, (and if there's no extra load in the car, the coil springs are broken or sagging.
    centaur's Avatar
    Aug 2006
    Alberta. Canada
    411
    Maybe I've been seeing cars with either coil over replacements or maybe just faulty ELC systems. Thanks, good to know. It seems all the SLS models sit much higher in the rear than the STS? I've been contemplating buying an SLS as a daily/winter driver, but I don't like the rear ride height they all seem to have.
  16. #14
    Sep 2010
    East Boston MA.
    29
    26,325
    Some SLSs seem to sit higher, as well as F55 STSs. You can always modify the position sensors control arm and adjust it to where you want. But there are ride height specifications in the FSM. Go out of spec and you'll have alignment issues.
  17. #15
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,350
    Quote Originally Posted by centaur View Post
    MoistCabbage is SPOT-ON - as usual -
    NOTHING -
    if the system was working properly BEFORE going PASSIVE -
    it will continue working properly afterwards -
    our Sevilles have 3 types of suspension -
    PASSIVE -
    F45 - CVRSS -
    F55 - MAGNARIDE -
    they ALL have ELC - Electronic Level Control -
    if the rear end is sitting too high -
    there is a problem -
    a failed exhaust solenoid within the compressor assembly -
    out of adjustment ride-height sensor -
    missing ride-height sensor connecting rod -
    or the ELC system was changed to coil-over shocks -
  18. Remove Advertisements
