84 Biarritz Convertible Electrical problem
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, 84 Biarritz Convertible Electrical problem in Past Cadillac Vehicle Discussion; I just noticed after getting one of my convertibles ready for spring that I have an electrical problem. passenger seat ...
    ralphiedee is offline Cadillac Owners Fanatic
    Automobile(s): (2)1984 Eldorado convertibles
    Apr 2011
    106
    passenger seat switch does not work
    door light on bottom right is out
    Door locks do NOT work, ON BOTH SIDES but I hear the relay
    when top is opened all windows go down except for passenger window.
    only the window switch on the passenger door works
    Driverside seat works fine
    all windows work fine from drivers side.
    I know its not the seat switch as I tried a good one from my other car.
    any suggestions before I grab the voltmeter?
    R
    scottelderado's Avatar
    scottelderado is offline Cadillac Owners Fanatic
    Automobile(s): 1985 Eldorado Biarritz Convertible, Sable Black, HT4100
    Aug 2012
    Washington, D.C.
    493
    Re: 84 Biarritz Convertible Electrical problem
    Hi Ralphie, when I bought mine, many of the door switches didn't work. I removed them from the doors, cleaned them up with some electrical contact cleaner and q tips, reconnected and most or all functions worked. The switches are like 1960s technology. They're poorly designed and they seem to separate on their own. And seems they can get dirty easily. Try cleaning them.
    Feb 2003
    california
    69
    6,663
    The plug in connector for the door switches is connected vertically to the switch. Its held in place by at least one blue twist on lock the size of a dime. I've seen those missing which allows for the switch to loose contact after years of slamming the door. The same for the reflector bulb in the lower door. Years of slamming can break the filament.
    Apr 2011
    106
    Thx for the replies, I have an update here and after moving the door light clip around it now works. So the next thing is the door locks.
    When I hit the driver OR PASSENGER side I hear the relay but the locks don't work. TWO BAD SWITCHES???
    Next is the power seat switch on the pass side. The switch is good cause I took it out of my other Biarritz but seat still does not work
    and last is when you open the convertible top on these cars the windows go down automatically. All except the passenger window.
    R
    Feb 2003
    california
    69
    6,663
    Humor me and check or replace the yellow 20 AMP BODY fuse. Located above the parking brake pedal, behind a large group of wires in the fuse box.
    Apr 2011
    106
    I found out what the problem was, behind the glove box near the replay for the door locks is another relay that was wired in, one side was disconnected from a cli. I reconnected and now both the door locks and passenger seat works.
  9. Remove Advertisements
