Help finding clunk from front-end
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
Like Tree1Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Help finding clunk from front-end in Past Cadillac Vehicle Discussion; My 2001 STS has developed a clunk in the front, and I'm having a heard time pinpointing the cause. (Around ...
    ocgltd's Avatar
    ocgltd is offline Cadillac Owners Fanatic
    Automobile(s): 2001 STS
    Oct 2008
    London Ontario
    300
    My 2001 STS has developed a clunk in the front, and I'm having a heard time pinpointing the cause. (Around 4000km ago I had the engine out for a head studs job - in case that's a clue).
    Sometimes I hear it going up a curb (pulling into the driveway) when the FR wheel goes up. I can sometimes reproduce it steering left-right-left-right at low speed (I haven't tried at high speed for obvious reasons).
    It sounds like it comes form the center of the engine compartment, and its a heavy CLUNK sound. It doesn't feel like the clunk is coming up the steering column.
    My guesses are:
    1. engine mount loose
    2. ball joint
    3. stabilizer bar bushing
    4. strut
    5. anything that moves under the hood
    Any suggestions on how to diagnose this?
    oldstuff is offline Cadillac Owners Fanatic
    Automobile(s): 66 convert-93-96-97-97-99 Eldorados
    Nov 2013
    McCleary Wa.
    81
    460
    Re: Help finding clunk from front-end
    Do a double check of the cradle mounting bolts. sounds like cradle shifting, maybe not tightened when engine work was done.
    Dave
    Quote Originally Posted by ocgltd View Post
    My guesses are:
    2. ball joint
    4. strut
    ocgltd's Avatar
    Oct 2008
    London Ontario
    300
    The engine actually came out the top, so cradle should be tight. But I'll check the bolts...
    68
    81,916
    Based on your description I think your could pretty much rule out a motor mount.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,368
    swaybar link -
    swaybar bushing -
    broken/loose steering rack -
    Yaemish is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Seville, 04 SRX
    Sep 2003
    NY
    1,224
    Torn rubber in the strut mount?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    The shake has nothing to do with the sway bar.
    ocgltd, have you checked the control arm bushings?
    ocgltd's Avatar
    Oct 2008
    London Ontario
    300
    OK - I found something! I discovered that on left hand control arm there is a stopper (looks like a 5" piece of black pipe with rubber bushings) for the sway bar, but on the right hand side it is missing. (and I can see shiny metal where it used to be mounted).
    I don't know what this piece is called, but perhaps the sway bar swings too far down and hits the control arm now? Could this be my clunk?
    Would someone know what this piece is called? (I'm guessing it's a dealer only piece).
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,368
    sway bar link - should be one on each side -
    68
    81,916
    This help Any?
    http://www.gmpartsgiant.com/Page_Pro...042&SortKey=18
    ocgltd's Avatar
    Oct 2008
    London Ontario
    300
    Parts 18/19/20/32 combined looks like the tube & bolts that I need. Is this available as a kit? (is 37 the whole kit?)
    Am I interpreting the picture correctly: that the sway bar floats above the tube, and only pushed down on the tube when the other wheel drops?
    Or should the sway bar be permanently connected to the control arm? (Should bolt 18 go through the control arm, through the sway bar, and secure them together? (On my car one side is missing the tube (32) and both sides the end of the sway bar seems to have a strange bolt and bushings attached but free from the control arm.) I'm wondering if maybe the bolt is broken on both sides?
    On both sides the sway bar has a rubber bushing on each side of the sway bar end, and a bolt through it with a strange bolt on the bottom...looks like twisted metal. I'm starting to thing may the bolt is broken on BOTH sides?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,368
    SWAY BAR LINK -
    MOOG K5255 - less than $6 per side -
    ocgltd's Avatar
    Oct 2008
    London Ontario
    300
    OK - I'll have to look into the sway bar link for each side. A couple more questions:
    1. I found some comments online about 19 vs 21 mm bars. Would I have to ask the dealer for the size based on my vin?
    2. Is this a DIY job? I also read that you need a lift to do this job...
  16. #14
    Sep 2010
    East Boston MA.
    29
    26,325
    The STS Would have the thicker bar, but that makes no difference, same links. It's an easy DIY job with a jack and stands.
  17. #15
    ocgltd's Avatar
    Oct 2008
    London Ontario
    300
    I there a link for how to do this job? (Only 2 postings I found say you need a lift).
    I'm guessing you need to lift both front sides at once, then sway bar should be free?
  18. Remove Advertisements
