Results 1 to 5 of 5
Thread: How do i disconnect throttle cable and cruise control rod on a 85 seville
    omston is offline Cadillac Owners Fanatic
    Automobile(s): 1985 Seville
    Jan 2014
    316
    How do i disconnect throttle cable cruise control rod from throttle body. The plastics so old i don't want to force it and break it.
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    Re: How do i disconnect throttle cable and cruise control rod on a 85 seville
    I pulled the keeper on the other end of the rod in the vacuum diaphragm, I then depressed the diaphragm to get the rod out. Then I pulled the rod at an angle away from the ball socket on the throttle body. Make sure and note which hole you remove the keeper from! Just be gentle!
    Jan 2014
    316
    Thanks for your reply got it off without braking it just forced the throttle cable off only way. I'm good at doing real difficult intricate task but little mickey mouse stuff throws me.
    By the way i couldnt really see the rod when i removed the keeper i assumed it only had one hole not a half a dozen do you know which one it goes in?
  5. #4
    oldstuff is offline Cadillac Owners Fanatic
    Automobile(s): 66 convert-93-96-97-97-99 Eldorados
    Nov 2013
    McCleary Wa.
    81
    460
    With the throttle completely closed put it in the hole that leaves the least slack. Don't get to tight or your engine won't idle down. Adjustment is why there are holes.
    Dave
    Quote Originally Posted by omston View Post
  6. #5
    Feb 2003
    california
    69
    6,688
    The manual states to adjust to very little slack with the ICV retracted.
  • You may not post replies
