How do I get to the BCM
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, How do I get to the BCM in Past Cadillac Vehicle Discussion; I can't get the back seat off to check the BCM, is the a trick to it? Do I have ...
    fltdriver is offline Cadillac Owners Fanatic
    Automobile(s): 1999 ELdorado
    Feb 2014
    137
    I can't get the back seat off to check the BCM, is the a trick to it? Do I have to access it through the trunk? Any help would be appreciated.
    I've got the bottom seat out but can't figure out the back rest. I tried going at it from the trunk but the nuts holding the black plastic casing don't want to move. I'm losing patience with this freakin seat. Do I even need to remove the backrest or is the BCM on that black plastic casing/or accessed with it out of the way?
    68
    81,889
    Re: How do I get to the BCM
    Access it through the trunk.
    Feb 2014
    137
    As I was taking the upper bolts of from the trunk side the back seat finally gave way, thanks though.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    There is no BCM; the correct terminology is PZM.
    It is accessible once removing the rear seat back rest.
    Normally should be accessible from inside the vehicle but the plastic tray housing the rear electronics bay components can be unclamped once the seat rest top screws are removed (plus 2 more for the tray). It can be flipped down into the trunk, the wires are long enough to allow the movement. But again the tray is meant to be accessed from the inside the vehicle.
    Feb 2014
    137
    Sorry, that's just what/where the instructions said "NOTE #3: the BCM is located behind the Drivers side of the Rear Seat back, it has (2) plugs
    labled C1 and C2."
    What does PZM stand for?
    68
    81,889
    BTSOM
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    PZM = PLATFORM ZONE MODULE.
    The '98+ gen V design with DIM and RIM (the equivalent of PZM in gen IV) was intended for long time.
    Before use to be called Body Control Module (BCM) but it took too may wires to run from the various places in the vehicle all the way to the BCM. So they idea was let's split it in more localized modules having just 1 wire (data line) in between.
    The PZM was renamed before actually being split and funny enough once split it was renamed again to Rear Integration Module (deals with controls located in the rear side of the body) and Dash Integration Module (dealing mostly with the front side of the body).
    There ared few modules with an interesting name/history:
    "PCM" - Powertrain Control Module (not just ECM) as it deals with the transmission too.
    "RIM" - Radio Integration Module up to '95 accurate terminology, later on '96-'97 (Seville, -'99 Deville, -'02 Eldorado) was incorrect as the module function was a Sound Processing Module (not dealing at all with the Radio). In gen V it was renamed AMP when the name kind of became again not very accurate (AMP is one of the functions, it also includes the sound processing earlier functions).
    RIM vs RIM (Radio Integration Module vs. Rear Integration Module) confusion with gen IV and gen V Seville, further more up to '02 same module (RIM) had different meaning in different models.
    Back to PZM/DIM/RIM, well gen IV PZM+IPC functions were spread in between IPC+DIM+RIM (mainly IPC lost some of its functions to the DIM).
    Generally since they started adding electronics to the vehicles the trend was towards integration (lesser modules/more functions in one module), with the exception of the body functions where the current was to create zonal modules (rather than per function modules).
    The goal is cost reduction, weight reductions (lesser wires), faster assembly times.
    xandrew1986x is offline Cadillac Owners Member
    Automobile(s): 1997 Deville
    Sep 2014
    30
    10
    N*CADDY Sorry to interject here but looking through all of the forums here you seem to be pretty knowledgeable,I really need help please check out the thread I started here; http://www.cadillacforums.com/forums...-no-start.html and my issue is in the first post. I'm not sure how to alert you to my thread any other way, it said your DM mailbox was full?
    Thank you in advance.
    Andrew.
  11. Remove Advertisements
