Power Steering Pressure Sensor Malfunction
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, Power Steering Pressure Sensor Malfunction in Past Cadillac Vehicle Discussion; So I cleaned the TB a little while ago as well as the IAC valve, both were pretty grimy and ...
    fltdriver is offline Cadillac Owners Fanatic
    Automobile(s): 1999 ELdorado
    Feb 2014
    137
    QuestionPower Steering Pressure Sensor Malfunction
    So I cleaned the TB a little while ago as well as the IAC valve, both were pretty grimy and now the 99 Eldorado idles much better (just over the 750 marker). My question is when I went in to reset the codes to get rid of the SERVICE IDLE CONTROL message I wrote down all of the codes displayed and needed some guidance as to what some of them mean
    Current
    P0550-Power Steering Pressure Sensor Circuit Malfunction
    History
    P0603 ICM KAM
    B1348 Low refrigerant
    B1327 Device Power Circuit Low
    Battery has been unhooked recently so that explains 0603, I have cans of 134a and plan to do that soon.
    What exactly does Device Power Circuit LOW refer to, my thought this was another one thrown by the battery being disconnected.
    And what can I do about the current 0550, or what needs to be investigated to fix it? Power Steering seems to work just fine, maybe a slight belt squeal if wheels are turned while car is at a complete stop.
    Feb 2014
    137
    Re: Power Steering Pressure Sensor Malfunction
    I also have a hose coming out of the top of the transmission (almost right under the MAF) that is about a foot long with a free spinning metal cap. I wasn't sure if this was supposed to be like this (some sort of pressure relief or breather) or if someone deleted something then capped off the hose. Wish I would have taken a picture of it because I know that my description is probably lacking but any help would be appreciated.
    Feb 2014
    137
    Figured out the PSP Sensor Malfunction when I replaced the oil level sensor and connector I noticed another connector just hanging beneath the car. Plugged it back in and the code went away. The steering was easy to turn before but now it seems super responsive, may just be a placebo effect.
    Never did find out what that hose is for.
    rodnok01's Avatar
    Feb 2012
    NC
    6,701
    That hose is the transmission vent line. Supposed to have a metal cap that moves freely and be clipped up to throttle bracket area. Half the time i see the clips are broken.
    Feb 2014
    137
    thanks, hoped it was supposed to be like that.
  8. Remove Advertisements
