what tube connects to the heater core
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Like Tree1Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, what tube connects to the heater core in Past Cadillac Vehicle Discussion; What tube is connect to the heater core .every time I put antifreeze in Its runnin out like water...
    cadillactony is offline Cadillac Owners Member
    Automobile(s): 1997 cadillac serville
    Nov 2013
    kansas
    32
    rodnok01's Avatar
    Feb 2012
    NC
    6,653
    Re: what tube connects to the heater core
    2 heater hoses and 2 metal pipes that go behind the engine. Look to see where it's leaking, those pipes are known to rot out.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,489
    Quote Originally Posted by cadillactony View Post
    heater hoses - one in - and one out -
    probably the metal pipe -
    not uncommon for them to rust out after 17 years -
    check the TECH-TIPS forum -
    I think there was a HOW-TO fix it using heater hose -
    rodnok01's Avatar
    Feb 2012
    NC
    6,653
    I will be replacing one myself very soon, it has flaking paint and has seen better days.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,276
    cadillactony, Please do NOT multiple post the same question in different forums. Thank you. Threads merged.
    There are two coolant lines - supply/return - going to/from the heater core. Center of the firewall.
    What is your problem ??? Coolant leak ? At the surge tank (reservoir) ?
    sts 03's Avatar
    sts 03 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 sts
    Oct 2011
    d.c metro area
    37
    1,754
    There is also a heater pipe going into the back of the crossover into a quick connect fitting that can leak.
    Nov 2013
    kansas
    32
    How do I take the pipes off
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Is it leaking from the two heater lines going into the firewall?
    Nov 2013
    kansas
    32
    Yes...
    The pipes look old I have never change them in five years
    68
    82,083
    With great difficulty, many four letter words and several bandages. You may need to lower the front of the cradle for access.
    rodnok01's Avatar
    Feb 2012
    NC
    6,653
    Don't just assume it's the pipes dude... could be ANYTHING at this point.
    68
    82,083
    Yeah, as big of a PITA job as this is, you want to be damned sure they need replacing.
    Nov 2013
    kansas
    32
    Not assume nothing that's where its leaking from
  16. #14
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    Two hoses (inlet and outlet hoses) go to the heater core from the passenger side, off the heater pipes.
  17. #15
    Nov 2013
    kansas
    32
    Yeah I got the heater lines of it goes from the passenger side to the drive side
    Now how do I remove the tool bolts I tryed to do it with ratchet
  18. Remove Advertisements
