1999 SLS battery drain
Results 1 to 9 of 9
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1999 SLS battery drain in Past Cadillac Vehicle Discussion; howdy my sls has a drain ,new battery, new alternator, grounds clean, lights off any ideas? thanks!!...
    wyattkenneth is offline Cadillac Owners Member
    Automobile(s): deville and sls
    Mar 2014
    59
    4
    68
    81,764
    Re: 1999 sls battery drain
    Pull the negative battery cable and place a 12v test lamp in line between the cable and the battery terminal. A drain should illuminate the test lamp. Start pulling fuses until the lamp extinguishes. That will tell you what circuit or component to focus on.
    Mar 2014
    59
    4
    howdy thank you fer quick reply will do i have read an old reply about the bose amp to a guy in england i belive it was from you. thanks again have looked at this fourmfor years this was my first post, yall have help me many times in the past thank you very much have a great day
    Mar 2014
    59
    4
    Re: 1999 SLS battery drain
    howdy it ending up being the onstar / phone module in trunk passenger side disconnected it no more draw.
    oldstuff is offline Cadillac Owners Fanatic
    Automobile(s): 66 convert-93-96-97-97-99 Eldorados
    Nov 2013
    McCleary Wa.
    80
    460
    Just for information to anyone trying this method of finding the battery draw. I thought it made perfect sense so I tried it and I pulled every fuse and relay one at a time and the light stayed on. Then I pulled all the fuses and relays and the light was off so I started to insert them one at a time till the light came on. When it came on I pulled that one back out and continued replaceing them and the light came on with another one. Seems there were two circuits causing the draw and pulling one at a time didn't disconnect the draw.
    Dave
    Harry Yarnell is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 XLR, '96 eldo,'95 eldo,' 89 eldo,'78 eldo,'11CTS-V
    Dec 2004
    perryman, MD
    72
    803
    This Insertion of a test lamp has a flaw.
    A number of circuits stay 'active' for a short period of time after key off.
    I've replaced the test lamp with an amp meter and watched the current after the key was turned off. Couple amps for many minutes...and in wasn't all out at the same time.
    I forget what sleep mode draws; 20-30 ma.?
    Nov 2013
    McCleary Wa.
    80
    460
    Does that apply with the battery cable disconected? The only voltage entering the system is what comes through the fillament of the test light bulb so I would think the ability of the delay protocal would be nullified.
    Dave
    Quote Originally Posted by Harry Yarnell View Post
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    55,590
    RAP drops several different modules over a 10 minute period. After that, residual current draw is usually 15 - 25 mA.
    Any operation of doors or equipment during RAP hold drastically changes current draw.
    There should be no vehicle voltage present if the battery is disconnected ???? Yes, some modules have onboard capacitors or a ?lithium cell?, but you should not be able to see than on the main bus.
    Depends on the test lamp bulb - all my Hickok vacuum tube testers use a 6 volt automotive single filament bulb as a fuse - and that bulb can pass quite a bit of current.
    Dec 2004
    perryman, MD
    72
    803
    A
    Ah yes, Hickock tube testers. Remember those back in the day when I was doing tv service.
  12. Remove Advertisements
