99 Eldorado - no fog lights
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, 99 Eldorado - no fog lights in Past Cadillac Vehicle Discussion; I was wondering where I could find the relays for the fog lights? My light on the dash doesnt come ...
    cglawrence is offline Cadillac Owners Member
    Automobile(s): 1999 ETC Eldorado
    Mar 2014
    NC
    6
    I was wondering where I could find the relays for the fog lights? My light on the dash doesnt come on and neither do the lights. If I knew what relays to look for or if anyone had a schematic, it would be sooo useful! thanks. Oh, I keep getting the PCM P0442 vaccuum leak(minor) should I replace gas cap. It looks kinda ruff and it is no longer attached to the car.
    Sep 2003
    Metro ATL
    4,854
    Re: 99 eldorado no fog lights. Help please!
    Relay; Underhood Relay Center
    Fuse; 10A, Underhood Fuse Block
    Mar 2014
    NC
    6
    the fuse is fine but still no fog lights. is there a relay somewhere i can check or replace? if so does anyone know where it is located?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,480
    Quote Originally Posted by cglawrence View Post
    fuse and relay information begins on page 6-56 in the Owners Manual -
    if you don't have the OM -
    go here for a free download -
    http://www.devicemanuals.com/support...al-110363.html
    fltdriver is offline Cadillac Owners Fanatic
    Automobile(s): 1999 ELdorado
    Feb 2014
    137
    Pull the plastic case around the underhood fuse panel, this will reveal the relays and maxi fuses. Flip the case over for a diagram on which relay it is. On my eldo it's the middle one on the bottom of the 6 relay cluster.
    Mafiaman111 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville 159k
    Oct 2010
    Pennsylvania
    449
    Once you pull the fuse check for corrosion down in the pins
    2manyhotrods's Avatar
    2manyhotrods is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Eldorado ETC coupe.
    Jun 2013
    Massachusetts
    438
    I know this sounds dumb but did you turn on your headlights first before hitting the foglight button?
    Ask me how I figured that one out. Embarrassing.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Headlights and gig lights operate independently. Turning on the high beans will disable the fig lights though.
  11. Remove Advertisements
