Page 1 of 3 123 LastLast
Results 1 to 15 of 42
Thread: 2002 SLS not starting after radio install ***update***
    daddyruiz820 is offline Cadillac Owners Member
    Automobile(s): 2002 Cadillac Seville SLS
    Aug 2013
    35
    47
    2002 SLS Aftermarket double din installed
    Just had a double din installed and now car won't start. I can hear the relay but no crank what so ever. Any ideas?Guy says it's the factory security but I'm not sure. Never had a problem like that. Need help asap
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,698
    Re: 2002 SLS Aftermarket double din installed
    Quote Originally Posted by daddyruiz820 View Post
    Cadillacs do NOT like their electronics messed with - by amatures -
    the security system goes throughtout the entire car - and through MOST modules -
    do a simple radio install WRONG - without the special adapters/modules -
    and you WILL be PLAGUED with electronic problems - FOREVER -
    Aug 2013
    35
    47
    I'm hoping not. They installed one on another car and it worked fine. Looking for a solution here.
  5. #4
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,698
    but - was the other car a Cadillac?
  6. #5
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    It's almost definitely not the factory anti theft system (PassKey III) Look on your receipt. Do you see the words "integration module" or "GMOS-06 anywhere?
  7. #6
    Aug 2013
    35
    47
    Yes other car was exactly same year and model.
    @moistcabbage no I don't see that anywhere. What exactly is that so I know what I'm talking about when I talk to these guys.
  8. #7
    Sep 2010
    East Boston MA.
    29
    26,323
    Your original HU was part of the anti theft system and data serial bus. The module allows everything to continue to "talk to one another" even though the HU is no longer there. Without it (or with a bad install/wrong module/faulty module), you'll have all kinds of electrical issues.
  9. #8
    cadi509's Avatar
    cadi509 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS V Tango int
    Jan 2010
    Yakima, Wa
    28
    2,337
    But did the other car have Bose or non Bose that is the key
  10. #9
    Aug 2013
    35
    47
    Not really sure. It was actually STS.
    @moistcabbage so I should have them install GMOS? That will make it ok?
  11. #10
    Sep 2010
    East Boston MA.
    29
    26,323
    An integration module is required weather the car has Bose or not.
    You need to find out what they installed. You NEED an integration module. The GMOS-06 is the Metra unit, PAC makes one as well.
  12. #11
    Aug 2013
    35
    47
    Sounds good. Will look into it in the morning and post back. Thanks to all.
  13. #12
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    Is it
    STS = Bose
    SLS = Base
  14. #13
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,848
    If they didnt offer or advise having a module be installed, id say might've spliced into the wiring at the rim to bypass the amps.
  15. #14
    Sep 2010
    East Boston MA.
    29
    26,323
    No, many SLSs have the Bose system.
  16. #15
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,848
    Ah ok. So the OP might want to pull the top trunk liner to get access to the RIM and inspect the wiring. The C2 connector has the data lines.
  • You may not post replies
