flickering dash lights 300K miles 96 eldo
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, flickering dash lights 300K miles 96 eldo in Past Cadillac Vehicle Discussion; My wife noticed her dash lights flickering but not noticable on the head lights. On the digital display the voltage ...
    oldstuff is offline Cadillac Owners Fanatic
    Automobile(s): 66 convert-93-96-97-97-99 Eldorados
    Nov 2013
    McCleary Wa.
    81
    460
    On the digital display the voltage goes from 13.3 to14.6 in variable increments about three times a second. Almost to fast to read.
    Could it be such a low milage alternator could be failing? It's the original. Or could it be a relay ratcheting somewhere.
    There are no other indications I can see.
    Dave
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,148
    Re: flickering dash lights 300K miles 96 eldo
    DIC or a control module losing a ground ??? Look at your stored DTCs.
    Steady headlights or minimal lighting fluctuation during load changes doesn't point a finger at the alternator or voltage regulator............ even an alternator connector problem would affect the whole system.
    Nov 2013
    McCleary Wa.
    81
    460
    Thats what is so weird about it. The voltage on the DIC changes so fast you can hardly read it.
    I'll pull the codes probably this weekend unless it blows before then.
    Dave
    Quote Originally Posted by Submariner409 View Post
    Feb 2006
    57,148
    Pulling codes takes 1.5 minutes and a notepad. Sitting in the driveway or waiting for sushi.
    Nov 2013
    McCleary Wa.
    81
    460
    True but the car isn't here now.
    Maybe the head lights not flickering are due to some kind of dampening in the HID circuits?
    Dave
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    If you've installed an HID kit, the ballasts will keep the voltage to the bulbs constant.
    Nov 2013
    McCleary Wa.
    81
    460
    That was my thinking on it also.
    The car won't be here till late and leaves before daylight but I'll read the codes when I can.
    Dave
    Nov 2013
    McCleary Wa.
    81
    460
    The only codes are TC and RS and converter clutch nothing else before it finishes the readout.
    Not much help there. I started it after reading the codes and the voltage is still flittering around like a butterfly.
    Dave
  11. Remove Advertisements
