91 Seville Remote entry issues
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, 91 Seville Remote entry issues in Past Cadillac Vehicle Discussion; Hey guys, So I've had my Cadillac for a little over a year and I figure it's time I asked ...
    JonnyW is offline Cadillac Owners Member
    Automobile(s): 1991 Cadillac Seville STS
    Feb 2014
    7
    Question91 Seville Remote entry issues
    Hey guys, So I've had my Cadillac for a little over a year and I figure it's time I asked someone about this. (Also, I looked and didn't see any previous threads but if I'm reposting a question please let me know and point me in the direction of the answer.)
    When I bought my car, I was unaware that it had a remote entry system installed, as a remote was not included with the keys. It became apparent only when someone used their remote to lock their car and my car doors all unlocked. I've found no pattern as to what remotes work or don't, but it seems that a wide spectrum of people have this effect. It's especially worrying when my doors all unlock as I'm driving down the street. I've located the remote entry module and, in an attempt to fix the issue, tried unplugging all the wires from the box. Apparently, the non-remote functions for the power doors, trunk, etc. also route through the box, so I had to plug them all back in. My questions: Why do so many remotes work on this receiver? Would programming a remote to the receiver fix this issue? If not, is there a way to bypass the remote part so no remotes work on my car?
    It may also be worth noting that it is (I'm 99.9% certain) a factory-installed remote system.
    I appreciate any help you can give me.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    Re: 91 Seville Remote entry issues
    Quote Originally Posted by JonnyW View Post
    actually - it's incredibly RARE - virtually unheard of -
    that ANY random remote would work on your car -
    assuming the RKE - Remote Keyless Entry is working properly -
    possibly - but -
    you don't program the remote to work with your car -
    you actually program the car to recognize the remote -
    here is a link to the programming procedure -
    http://remoteandkeyprogramming.com/Programming/195.html
    I wonder if the "GREEN" wire is still grounded -
    you will understand this when you read the directions -
    with the limited searching I did -
    I believe the correct remote part number is GM 10178734
    Feb 2014
    7
    Thanks for getting back to me so quickly. I'll have to open it up and see if the wire is still grounded. I checked amazon and it looks like there are some used remotes for pretty cheap. I might try to pick one up and see if that works.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    check ebay - quite a few listed cheap -
    Feb 2014
    7
    Alright, I'm stumped. According to this website (which is, incidentally, the most information on this subject I have been able to find), the keyless entry module should be mounted in the trunk compartment, just under the center brake light. However, when I opened it up, this is what I found: And here's the keyless system that I actually found: That's mounted under the passenger-side dash, same way you would access the fuses and relays under there.
    And a close-up of the box: I just assumed that was the factory box since it looks the right age and has GM on it instead of one of the popular aftermarket names. I'm totally at a loss here as there is no good information on the internet. I'm hoping someone has more knowledge or firsthand experience with this and can help. Is this an aftermarket system, and how do I program this system? If I can't program it, how can I disable the system without disabling most of my electrical system, like in my first post?
    delerium75's Avatar
    delerium75 is offline Cadillac Owners Fanatic
    Automobile(s): 1991 STS, 1992 Fleetwood, 1987 Maxima wagon
    May 2008
    Bay City, MI
    42
    276
    Is there a part number and/or a wiring diagram on the back of the Goodwrench module?
    I'm guessing it's either an upmarket, dealer installed one (maybe includes a shock sensor) or a replacement for a failed keyless entry module (the one that should be in your trunk). From what I found searching, it's most likely some other manufacturer with a Goodwrench name slapped on, maybe a Code Alarm. It looks very similar to this: http://www.fiero.nl/forum/Forum4/HTML/068998.html.
    Which most likely means you need a remote like this: http://cgi.ebay.com/ws/eBayISAPI.dll...tchlink:top:en If you scroll down the listing, it shows the systems it's compatible with and also has instructions on how to program it to the module. If you search for the general remote number, GOH-MM6-101890, you'll see ones with Ford logos, Chrysler logos, etc. so there doesn't appear to be a shortage of them.
    If the module has a model number, it should be possible to find the correct remote for it. Otherwise, maybe a stereo/alarm shop might be able to point you in the best direction.
    Feb 2014
    7
    Hey, sorry it's taken me so long to respond. There is a number on the back of the unit, but from my research, it doesn't seem to correspond to any part numbers. That one you linked to does look a lot like it. I'll see if I can find anything new with this info. Thanks for your help!
  10. Remove Advertisements
