2002 Seville SO high idle
Page 1 of 2 12 LastLast
Results 1 to 15 of 30
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2002 Seville SO high idle in Past Cadillac Vehicle Discussion; Yet ANOTHER problem with my cadi. Out of nowhere it started idling high. When in D idles between 1&2. In ...
    daddyruiz820 is offline Cadillac Owners Member
    Automobile(s): 2002 Cadillac Seville SLS
    Aug 2013
    35
    47
    Yet ANOTHER problem with my cadi. Out of nowhere it started idling high. When in D idles between 1&2. In neutral it shoots up to above 2. In Park damn near 3. Have pulled DTC codes
    IPM B1340
    PCM P0507
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Definitions?
    Aug 2013
    35
    47
    IPM B1340 air mix door one movement vault
    PCM P0507 idle speed high
    Sep 2010
    East Boston MA.
    29
    26,323
    When was the TB last cleaned?
    Aug 2013
    35
    47
    It's been a year
    Sep 2010
    East Boston MA.
    29
    26,323
    I would start with that. While you're at it, make sure the throttle/cruise cables aren't sticking.
    Aug 2013
    35
    47
    I was hoping not to have to take it all apart again. Since last time I removed it completely and used Carb cleaner in rags and brushes. Should I do that again?
    Also, how would I check to see if the cables aren't sticking.
    Sep 2010
    East Boston MA.
    29
    26,323
    No need. Just remove the intake ducting. Carb cleaner, a rag, and an old toothbrush. Make sure you clean the perimeter of the throttle plate too.
    First make sure that neither is snug and holding the throttle open. To check them thoroughly, I disconnect them and move them by hand. You could also hold the throttle open and move them by hand.
    Aug 2013
    35
    47
    How often should that be done? And what can be done to prevent build up?
    Sep 2010
    East Boston MA.
    29
    26,323
    Once a year. And that is what you do to prevent buildup. And if it is fine yearly, it shouldn't take much more than a quick spray and a wipe to clean it. Make sure you get all the ducting back on correctly. A leak after the MAF sensor will set mixture codes.
    Aug 2013
    35
    47
    Thank u very much. Will do and post back.
    69
    82,383
    Re: 2002 Cadillac Seville SO high idle
    If the TB was cleaned a year ago, that should not be the problem. Hard to imagine it could get THAT dirty THAT fast. If another cleaning doesn't help, you might pull the IAC valve and clean it and the air passage
    Aug 2013
    35
    47
    Where is that?
  16. #14
    Sep 2010
    East Boston MA.
    29
    26,323
  17. #15
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,139
    Re: 2002 Seville SO high idle
    Albums - the Community tab, Albums, the red Seville, 2 albums. 116 pictures of parts and stuff.
    from Cadillac Forums ...........
    http://lmgtfy.com/?q=cadillac+forums...c+cleaning&l=1
  18. Remove Advertisements
