97 Eldorado idles low at stop signs then stalls
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, 97 Eldorado idles low at stop signs then stalls in Past Cadillac Vehicle Discussion; Just bought the car a week ago and that is the only issue..i cleaned all valves and replaced spark plugs ...
    Eldorado1997 is offline Cadillac Owners Member
    Automobile(s): 1997 eldorado
    Feb 2014
    34
    1
    Just bought the car a week ago and that is the only issue..i cleaned all valves and replaced spark plugs and wires..i put all new everything under the hood. I have no check engine and no codes..car drives like its brand new..just cant figure out this issue..if i put it in neutral at stop lights it helps last about 30 seconds longer then the idle drops but it always starts right back up..i am lost on what to do.. Also 3 other mechanics looked at it and couldnt believe it was messing up sine it drives so well..someone please help
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Did you clean the TB?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,561
    Re: 97 eldorado idles low at stop signs then shuts off if i dont give it gas right aw
    Quote Originally Posted by Eldorado1997 View Post
    check/clean the throttle body - and IAC - Idle Air Control valve -
    because you are new - and we don't know your level of knowledge -
    I have to ask if you are "pulling" the codes correctly? -
    using the OFF and WARMER buttons method -
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,126
    Check your fuel pressure, probably needs a pump.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,578
    Eldorado1997, You do not need a poll for advice. Please use the replies in the thread. Poll stripped.
    69
    82,163
    Re: 97 Eldorado idles low at stop signs then stalls
    Also check to be sure your PCV hose in the rear cam cover is tight.
  9. Remove Advertisements
