Results 1 to 9 of 9
Thread: 02 STS trans issues.. amongst other things
    jcarama1 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Dec 2006
    46
    I have a 02 sts.. having major malfunction of the transmission
    its always been spitting out the speed limited to 90
    which is why I thought I didnt have fourth gear..
    I have been driving it for quite some time.. as that
    recently
    After a couple long trip it has rough time getting started.. from dead stop..
    now I have lost third gear.. so I am at 3500 going 45 miles an hour
    the code are including but not limited to
    pcm. p1847... newest one and I the read out page has been moved?
    trans codes
    p0734 incorrect 4th gear ratio
    p0551c no first or 4th gear
    p1811 max adapt and long shift
    newest one p1847 which if someone sees this and can give me the read out that would be great
    this is new too
    ttm b1982
    u1016
    rss 1652
    c0634
    c 0640
    c0710
    and I cant look them up cause the odb2 site is down
    this one
    "myweb.accessus.net"
    These are there but I am not worried about them because they ve been there since I had the car
    p 0300
    p 0410
    p1571
    p1644
    p1811
    I mean. I am not a perfectionist.. I beleive in the run move stop principals.. for it
    I have a parts car 99 sts as a parts car and the trannys already out of it
    and also MY radio has been off since someone broke in my car and I think the disc changer got wet and it kept cycling and drained the battery so I just pulled the fuse
    I dont know.. I am shit up a creek I think and I ll prolly have to r and r the transmission.. but I wont be happy about
    please let me know what the codes are if that is possible
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,689
    Re: 02 sts trans issues.. amongst other things
    Quote Originally Posted by jcarama1 View Post
    recently
    trans codes
    this is new too
    ttm b1982
    u1016
    rss 1652
    c0634
    c 0640
    c0710
    this one
    p 0300
    p 0410
    p1571
    p1644
    p1811
    where to start -
    the speed limited to 90 could be a suspension problem -
    not a trans problem - although - you DO have a trans problem -
    for codes - go here -
    http://www.cadillacfaq.com/faq/answers/dtccode.html
    maybe you should be concerned about them -
    P0300 is an engine misfire code -
    which means you are not hitting on all 8 cylinders -
    and depending what is causing the misfire -
    you might be destroying the cat converter -
    Dec 2006
    46
    The 0300 is history.. I replaced the coil pack a while ago and I fixed it..
    1847th.. 2/3 shift solenoid.. high voltage. .??? How would I fix this? How do I regulate the voltage
  5. #4
    Dec 2006
    46
    Re: 02 STS trans issues.. amongst other things
    does anyone have the removal and replacement of trans procedure for this car out of the book..02 sts te34 or someshit. Ill have to look at it again and what book is there to get.. and where should i get it..
    if you hhave the book and can scan them and send them my way.. I have nothing but nice things to say about you for the rest of your life
  6. #5
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,842
    It's quite involved. Let's not get into pirating large parts of copyrighted materials.
    www.alldatadiy.com for your car......... or ebay or www.helminc.com
  7. #6
    Dec 2006
    46
    send it to my email.. jcarama2@yahoo.com
    no need to make a public spectacle.. although it would save me some time waiting for a book to come in..
  8. #7
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    Support the engine, take alot of bolts out, hang the frame, pull out the axles, disconnect cooling lines ans electrical connectors, do alot of prying.
    Not for the novice in his garage or yard.
    Drop the pan & check for a broken solenoid first, but if you lost 4th before the other problem, it's probably also a bad band.
  9. #8
    Dec 2006
    46
    Quote Originally Posted by Aztec ETC ECS View Post
    I have taken the other tranny out cause I was scraping the other motor..
    so I didnt really take to much effort to be able to put it back together.. cause I still havent.. but I dropped the whole sub frame with the brake lines and the whole nine.. seems like a bit extreme.. I think I still had a big pain to the get the tranny off the frame.. even when it was on the ground and I had a cherry picker...
    which side should I hang the frame.. describe hang the frame.. have you done this before?..
  10. #9
    Feb 2012
    NYC
    50
    1,948
    Have only done it on a lift. Most of the time the frame is taken out but can be hung on the pass side ball joint.
  • You may not post replies
