Results 1 to 14 of 14
Thread: Valet mode won't turn off
    03seville is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac Seville SLS
    Sep 2009
    23
    Ok, I've been a member here since 2009, never had the need to post to much at all since the search gave me all the info I needed every other time. Now I'm finally giving up on my own searching abilities though and asking for help.
    For over 2 years now I have not had the homelink, trunk release, or fuel door release functional. The car acts as if it's in valet mode all the time, it started off intermittently but eventually just stopped all together.
    1) I check the valet switch multiple times, then threw the multimeter on it to verify continuity and all is good.
    2) Went under the rear seat and tested the relays and verified fuses, again everything checks out fine.
    3) Checked all the fuses under the hood just to be positive there wasn't anything possibly causing it under there.
    4) Verified ground in LR trunk panel was still functional.
    Now I'm lost, I'm not showing any codes related to this at all. What's my next step, or what else could be triggering this?
    The car is a 2003 Seville SLS
    69
    82,284
    Re: Valet mode won't turn off
    You are absolutely confident that the switch is not sticking or has a broken internal spring causing an intermittent contact?
    Sep 2009
    23
    The switch had no problem completing and disconnecting the circuit, that was my first thought in it. Over the course of time I have tested the switch on different occasions and never failed.
  5. #4
    69
    82,284
    Sounds to me like you are going to need a FSM so you can peruse the wiring schematic and find something common to all those components. Perhaps a ground you missed.
  6. #5
    Sep 2009
    23
    Was afraid of that lol but thank you for the responses. I'll keep digging and maybe someday this will work again
  7. #6
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,870
    Is there a multiple body ground connector block behind the passenger right foot kick panel ? The ground blocks in these vehicles may have a dozen black wires all tied to a single lug/stud. You would not be the first to find one or more wires loose in there.
  8. #7
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by 03seville View Post
    ....it started off intermittently but eventually just stopped all together.
    The 'intermittently' part of that screams relay to me. Except there are two relays involved in this circuit.
    There are two relays involved. In the rear seat box find the F/TNK DR REL relay and the TRK REL relay. Substitute a relay borrowed from another circuit for each of those relays.
    There are two fuses involved (a visual examination of a fuse is not conclusive!). In the underhood box a 10A fuse labeled ALDL and in the under seat box a 10A fuse labeled BODY.
  9. #8
    Sep 2009
    23
    Thank you, Ill go over everything mentioned tonight. This why I asked here
  10. #9
    Sep 2009
    23
    Quote Originally Posted by JimD View Post
    Thank you so much! I've always hated asking questions on the forum since most answers are hidden somewhere under search but after a couple years of headache my car is fully functional again after replacing the aldl fuse I never knew it even played a role in this circuit.
    Thank you again!
  11. #10
    Sep 2003
    Metro ATL
    4,854
    Thank you so much! I've always hated asking questions on the forum since most answers are hidden somewhere under search but after a couple years of headache my car is fully functional again after replacing the aldl fuse....
    You lived with that situation for a couple of years rather than ask a question? ? ? ?
  12. #11
    69
    82,284
  13. #12
    Sep 2009
    23
    As stupid as it sounds yes, lol I basically gave the car to my fiancee since I have a company vehicle for work.. So after I couldn't figure it out in the first place I left it alone and kind of forgot about it for awhile. Recently I've been driving the car more often and started looking into it again.
    I really wish I would've came through here earlier and asked, such a simple solution and I was thinking way to far into it
  14. #13
    Sep 2003
    Metro ATL
    4,854
    In a humorous vein, IF I had a fiancée (which I don't) she would be unlikely to quietly open the trunk with a key to reach the manual fuel door release to put gas in the tank. For several years!
  15. #14
    Sep 2009
    23
    Yeah she's never been happy about it lol I've heard about it a few times but never made it a priority
    She is happier than ever now that it's finally working again!
  • You may not post replies
