Car doesn't start over night during cold weather
Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Cadillac Seville / Cadillac Eldorado Forum Discussion, Car doesn't start over night during cold weather in Past Cadillac Vehicle Discussion; 2002 CADILLAC SEVILLE. We recently had a freeze and when i went out the next day car would not start. ...
    daddyruiz820 is offline Cadillac Owners Member
    Automobile(s): 2002 Cadillac Seville SLS
    Aug 2013
    35
    47
    2002 CADILLAC SEVILLE. We recently had a freeze and when i went out the next day car would not start. When i got a jump, after connecting cables battery volts read 15.6, still would not start. After a few minutes car started but voltage did not change. Battery would stay at 15.6 all day and not give me a problem. So, i had battery tested and result was bad cell, had battery replaced. Was good a few days, got cold again and this morning would not start. Same thing, battery still at 15.6. A friend of mine stated that voltage is too high and that may be harming my battery. Any help would be appreciated. Thanks guys.
    oldstuff is offline Cadillac Owners Fanatic
    Automobile(s): 66 convert-93-96-97-97-99 Eldorados
    Nov 2013
    McCleary Wa.
    81
    460
    Re: Car doesn't start over night during cold weather
    Your friend may be right. I've never seen a 15.6 reading. The Max I've seen on mine is 14.3
    Dave
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,852
    Quote Originally Posted by daddyruiz820 View Post
    FIRST -
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    that is not BATTERY volts -
    that is the voltage being produced by the alternator with the engine running -
    trying to charge the battery - and run all the electronics -
    with the key ON - and engine OFF -
    what is the voltage displayed -
    what brand battery did you get -
    is the new battery the correct group79 model -
    69
    82,383
    The last 3 Northstars I've had will regularly run with voltage in the low 15's. Never 15.6.
    Are the battery cables clean and tight?
    Aug 2013
    35
    47
    Checked all connections, everything tight and clean. Tried to turn key on, without turning engine on, turned all lights on, radio, hazards, windshield wipers, voltage never changed. Is there something that may have missed that regulates it or something? Battery is evrstart maxx 79 from walmart.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,852
    let's try this one more time -
    AND ALL ACCESSORIES/LIGHTS ETC OFF -
    what is the BATTERY voltage displayed on the DIC -
    it SHOULD be somewhere between 12.8 and 12.0 volts -
    there is a voltage regulator - built into the alternator -
    that controls the OUTPUT voltage - with the engine running -
    good choice -
    Aug 2013
    35
    47
    with the key ON - and engine OFF - 15.6
    AND ALL ACCESSORIES/LIGHTS ETC OFF - 15.6
    what is the BATTERY voltage displayed on the DIC - 15.6
    NEVER CHANGES.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,852
    NEVER CHANGES.
    something is drastically wrong -
    a 12 volt battery can't store 15+ volts -
    use an external volt meter -
    and check the actual voltage -
    directly at the battery -
    with everything off -
    then again with the engine running -
    I suspect a problem with the display -
    if you don't have access to a DVOM -
    you could try "resetting" the computers by -
    removing BOTH battery cables -
    and touch them together for a couple seconds -
    this acts like a "re-booting" -
    and erases the memory from some of the various modules -
    Aug 2013
    35
    47
    Do i do this while the car is running or while it's off.
    So, i just double checked all connections again, now i see a black wire with white stripe coming from negative cable, that has a grey plug on the end of it, and it is cut. Is that something of importance?
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,063
    To perform the computer "reboot" procedure touch the + and - battery cables together with the engine OFF for approx. 5 seconds. You may have to relearn the automatic up/down window feature. Hold window down at the bottom for 5 seconds, hold window up when it gets to the top for 5 seconds, then test each one to make sure it stuck.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,852
    BOTH -
    to "reset" the modules by touching BOTH battery cables together -
    this is done with everything - engine and all accessories - OFF -
    unbolt the NEGATIVE cable -
    unbolt the POSITIVE cable -
    hold the two cables together for 2 or 3 seconds -
    reinstall the POSITIVE cable -
    reinstall the NEGATIVE cable -
    turn the key ON - engine OFF -
    check the voltage on the display -
    HOPEFULLY - the read-out will be accurate -
    and display the correct voltage - in the 12 volt range -
    if YES - fire up the engine -
    and check the voltage - with the engine running -
    you should see voltage in the 13.3 to 14.6 range -
    interesting - but not relevant - to your immediate problem -
    69
    82,383
    I don't know if I would touch the cables together with the engine running. In fact, I don't think it is a good idea to remove either of them with the engine running.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,852
    WHOAA - I hope I didn't give that impression -
    turn EVERYTHING OFF - engine - accessories - ignition - etc -
    before removing the battery cables -
  16. #14
    69
    82,383
    Quote Originally Posted by basscatt View Post
    BOTH -
    Did I misunderstand?
  17. #15
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,852
    YES -
    this from #8 -
    BOTH -
    I am suggesting to use a DVOM directly on the battery -
    to get an accurate reading - BOTH -
    engine OFF -
    and engine ON -
  18. Remove Advertisements
