Results 1 to 3 of 3
Thread: 94 sls, eliminating a/c pump
    Beau2715 is offline Cadillac Owners Member
    Automobile(s): 1994 SLS
    Jan 2014
    8
    Question 94 sls, eliminating a/c pump
    I had issue with the idler pulley, and the housing is beyond repair, I was just wondering if the route if of totally eliminating a/c pump and just getting shorter belt is possible? It seem to be only thing in way of connecting a shorter belt to vehicle. Are there any other functions involved with the a/c system that would effect vehicle?
    69
    82,272
    Re: 94 sls, eliminating a/c pump
    The only other function is that the A/C is engaged when you go into the defrost mode so as to dry the windshield faster and obviously that would be eliminated. Other than that, nothing else is involved.
    Mafiaman111 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville 159k
    Oct 2010
    Pennsylvania
    449
    yes a shorter belt can be ran successfully but if it was anything like my experience the only belt that would not make a chirp noise was a goodyear gatorback belt and i believe the belt size 73 inch
  • You may not post replies
