Front brake sensors and maybe non-related trouble codes - 2002 SLS
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Like Tree10Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Front brake sensors and maybe non-related trouble codes - 2002 SLS in Past Cadillac Vehicle Discussion; Hi all like 8 month ago went to pepboys and got new brake pads and disk they told me I ...
    old_school is offline Cadillac Owners Member
    Automobile(s): CTS 2010 (2002 SLS R.I.P)
    Jul 2012
    SE Florida
    89
    Hi all like 8 month ago went to pepboys and got new brake pads and disk they told me I need it to replace the 2 front brake sensors check a few store around my way but they don't carry the brake sensors for the seville does anyone know of a good place online to get them @ a good price
    68
    81,759
    Re: front brake sensors (cadillac seville sls 2002)
    old_school likes this.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,576
    Re: front brake sensors - 2002 SLS
    Or simply clip off the worn sensor(s), bare the pigtail wire ends, twist together and insulate. It's a simple series circuit - any one sensor wears through, the circuit opens, the message shows. If you perform regular maintenance checks you don't need sensors anyway......... and the pads (most GM and replacements) have the old style spring fingers that screech when the pad needs replacement.
  5. #4
    Jul 2012
    SE Florida
    89
    thanks Ranger and Submariner409
    @ Submariner409 when you say (most GM and replacements) have the old style spring fingers that screech when the pad needs replacement. does this mean if I replace the brake sensors when ever I need to change brake pads or discs again I would also need to replace brake sensors again
  6. #5
    Feb 2006
    55,576
    The electrical sensors wear down as the (inner) pad wears. Eventually the circuit (embedded wire) breaks and the message shows. The electrical sensors are sacrificial, and they wear out BEFORE the spring fingers (if fitted) begin to screech.
    The spring steel fingers are riveted to the backing plate of the outer pads - they act exactly like dragging your fingernails across a chalkboard. They, too, are set to indicate terminal pad wear - you hear screeching upon brake application, it's time to change pads. You DO have some time to do the job, but the noise gets louder and louder the longer you wait.
    I did an EBC rotor/pad change a few years ago - no electrical sensors had worn out - so I simply bundled the sensor pigtails and wire tied them to the chassis. Cheaper to hear squeals than replace electrical sensors at $15 a pop.
    ............. BUT I still do my own tire rotations and for several reasons I occasionally change to different tires/wheels, so I have a good look at suspension and brake stuff while the wheels are off.
  7. #6
    Jul 2012
    SE Florida
    89
    thanks for the info on this I think am going to go ahead and just replace sensors I wish I new how to pigtail wire looks like it would be hard for someone like me that's never done this befor don't want to end up breaking something on the car I wanted to ask you something eles for like a year now the check engine light come out on me the car drives fine is there a sensors fuses in the fuses box under the hood or the fuses box in back that cloud be blown I hate seeing that check engine light
  8. #7
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,482
    Unplug the sensor and jump the two wires together in the plug.
  9. #8
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    If the check engine light is coming on, trouble codes are being set. You can pull your codes from the DIC, no scanner necessary.
    Go to the top of the Eldorado/Seville page, and read the "sticky" thread on how to pull codes. List any codes you find, AND THEIR DEFINITIONS, here (there's a link to code definitions within the sticky).
  10. #9
    Jul 2012
    SE Florida
    89
    Re: Front brake sensors and maybe non-related trouble codes - 2002 SLS
    Hi MoistCabbage I just did this how to video in the how to pull codes (DTC's) "sticky" thread when I frist ran codes test there were a lot of history which I guess they don't matter cause there old current I guess they were fix by previous owner don't know if this is right also I saw like 4-5 current problem when I frist ran the code test but did not write down the frist time and i hit the clear all codes now when i ran it the second time am just seeing two current codes and i know i saw more the frist time don't know if this because i hit the clear all codes which did remove history the two current codes are which i have no idea how to check for definitions are ABS C1246 and Amp U1000
    Edit : found this don't know if its right
    DTC C1246 Brake Lining Wear Circuit Open
    DTC U1000 Class 2 Communication Malfunction
    "sticky" thread
    SYSTEMS: (as of 1998)
    ABS (Antilock Brake System)
    AMP (Amplifier)
  11. #10
    68
    81,759
    Use the link provided in the Sticky to find the code definitions.
    Drive the car for a day or two and check them again to see what returned.
    C1246 is telling you what Sub told you. The brake wear sensor wire is broken, or worn through, causing an open circuit. Either replace the sensor or connect the two wires to close the circuit and bypass the system. Personally, I'd replace the sensors. I wish GM kept that feature and my car had it.
    old_school and old_school like this.
  12. #11
    Jul 2012
    SE Florida
    89
    Thanks Ranger am just glad to know that one of the current codes the DTC C1246 Brake Lining Wear Circuit Open is just the the brake sensor and is not going to be to much money to fix the link you give me www.rockauto.com there is about 20 parts for brake pad wear sensor don't know which one to get
  13. #12
    Feb 2006
    55,576
    Call Chris in Parts at Rippy Cadillac over there >>>>>>>>>>>>
    ...... and if you're only going to replace ONE wear sensor you need to know which one it is. (which wheel)
  14. #13
    Jul 2012
    SE Florida
    89
    Hi Submariner409 they told me it was the two front wheel sensor so am just going to go ahead and replace both
    Edit : are the two front brake wheel sensor the same for both wheel ?
  15. #14
    68
    81,759
    Yes the brake pad wear sensors are the same for the front wheels. Any one of them listed at Rockauto should work. Apparently the rears are different, though I can't imagine why.
  16. #15
    Jul 2012
    SE Florida
    89
    ok thanks Ranger I think I go with the cheap ones there around $7 each hope they come out good and long lasting for the other current code DTC U1000 Class 2 Communication Malfunction which I geuss has to do with the amp am going to have to leave it like that cause am not 100 % sure but I belive that's because I removed the factory radio and I put in a aftermarket radio and the amp is not working well with the aftermarket radio but then again this started happening like one year after I install the aftermarket radio so I don't know and don't know what I can do about this amp can I remove the amp or that's not a good idea
  17. Remove Advertisements
