1995 eldorado fan blower problem
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1995 eldorado fan blower problem in Past Cadillac Vehicle Discussion; OK, these are the things I have done: Checked all fuses in engine compartment and trunk Replaced fan motor, because ...
    korte4260 is offline Cadillac Owners Member
    Automobile(s): 1995 Eldorado
    Jul 2013
    11
    Replaced fan motor, because it was not working. ( I bench tested new fan before installing and it worked)
    The front fan does not come on, the back one does (I know the back one runs off different fuse)
    I have noticed that the back fan does not blow out warm air even though the car says the water temp is 212 degrees.
    Could this be a relay and if so which one and where is it located? How to test it.
    Thanks in advance for any advice or ideas.
    Jul 2013
    11
    Re: 1995 eldorado fan blower problem
    Well, hopefully someone will respond some time. I see 111 views and no reply. I have an update.
    I puled my new blower fan and decided to bench test it again. Well when I connected the battery positive to the blue wire on blower and battery negative to black negative blower wire nothing. So for kicks and giggles I switched my battery connection around and the fan spun. (put battery negative on blue wire of blower and battery positive to black wire on blower) What gives???
    Hopefully I can get some type of response from this forum. Thank you in advance for any information or help.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Have you pulled the codes?
    Jul 2013
    11
    Yes, they all come out clear. Could it be that the new blower was wired backwards?
    Jul 2013
    11
    Well, update.
    I reversed the positive and negative wires on the blower and plugged it in to the car. The fan turned on as soon as I had the connector plugged in. The car was not turned on or anything, so that is not the problem. I have since switched back the wires on the blower. I am getting power to the red wire on the blower plug and the black ground wire is working also. I jumped the red to the black wire and getting power. I know the red wire is always hot and connecting it to the black wire confirms hot wire and good ground. I am inclined to think it is the climate control module (middle wire), but how do I test. I don't want to spend more money on something I don't need possibly.
  8. Remove Advertisements
