A/C compressor help
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Cadillac Seville / Cadillac Eldorado Forum Discussion, A/C compressor help in Past Cadillac Vehicle Discussion; I noticed today when I turn on my ac the clutch kicks in but no cold air. The lines aren't ...
    s281er238 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 STS 28 k miles,2006 escalade ,2005 deville dts
    Sep 2011
    Burbank, California, United St
    36
    473
    A/C compressor help
    I noticed today when I turn on my ac the clutch kicks in but no cold air. The lines aren't getting cold as well. I checked for codes none just my check oil level came on this morning. The only thing I noticed is the sound isn't the same as it use to be when the clutch kicks in its a little off.my fans won't kick in either. Maybe low level freon need advice
    kaceyseldo's Avatar
    kaceyseldo is offline Cadillac Owners Fanatic
    Automobile(s): 97 eldorado
    Nov 2013
    30
    398
    Have it charged. Check for broken vacuum lines. It will be the line running from intake, in front of the coil pack, and in the firewall on the pass side. The rest are under the pass side dash. Does your e brake disengage when put it gear?
    68
    82,048
    Re: Ac compressor help
    Probably low on refrigerant, but you won't know until you hook up a set of gauges and get the low and high side pressures.
    Sep 2011
    36
    473
    I'll give it a shot thanks guys.
    Sep 2011
    36
    473
    Re: A/C compressor help
    What does the brake have to do with it just curious
    kaceyseldo's Avatar
    Nov 2013
    30
    398
    Your vent actuator and e brake run on the same vacuum line. Refer to the thread about a 97 etc with only defrost and floor vents working. It might help you out a bit without repeating the same things over again.
    http://www.cadillacforums.com/forums...-no-vents.html
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,471
    Quote Originally Posted by kaceyseldo View Post
    the OP's car is all electronically controlled -
    no vacuum - including parking brake release -
    kaceyseldo's Avatar
    Nov 2013
    30
    398
    My bad. What year is it?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,471
    Quote Originally Posted by s281er238 View Post
    in your case - absolutely nothing -
    the old Eldos use vacuum to control the climate control system -
    and the parking brake release is also vacuum powered -
    the OP has an 01 Seville -
    kaceyseldo's Avatar
    Nov 2013
    30
    398
    My mistake then. I'm out due to inexperience. Good luck.
    Sep 2011
    36
    473
    So I put stop leak freon one small and the rest cold charged it and works great for a week and now back not hot air the compressor still kicks in and the low pressure line where u charge it is cold when I turn it on but the thicker line Is not and do either a leak or a faulty compressor right. I will out the tester tonight and see if the gauge dropped again any other thoughts. I do notice te compressor does not have a same sound when it turns on and off thanks
    68
    82,048
    Now you've done it. NEVER use a stop leak in the A/C system. You have contaminated the system and will most likely have to replace every component. You probably will have a hard time finding a shop that will touch it should you need one.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,471
    WHAT?
    I understand you put AC stopleak in the system -
    and it worked for a week -
    you lost me after that -
    let me just say this -
    to diagnose AC problems -
    you need to connect a quality set of guages -
    then post BOTH the HIGH pressure readings -
    and the LOW pressure readings -
    along with the ambient - outside - air temp -
    and the air discharge temp at the center AC vent -
    with the temp set at 60* and a medium speed fan - with the engine at a high idle - 1500 rpm -
  16. #14
    Sep 2011
    36
    473
    It's wasn't stop leak sorry it was just the freon. I thought I got the one with leak stop but it wasn't just basic 134 a. I filled it last week and today when I put the gauge on the low pressure side it was back down to 170 below the green when yo should of been at level I had it. When I turn on the ac the clutch kicks in and the low pressure live turns cold but no cold air. I thing either compressor is acting up or a leak. I used some soppy water and I saw some bubble when the two lines enter the fire wall but don't thing the cause would be there.
  17. #15
    rodnok01's Avatar
    Feb 2012
    NC
    6,649
    So you did find something leaking? The connections at firewall or the lines themselves?
    You're using one of those cheap a$$ single gauge cans aren't you.... you need set of gauges.
  18. Remove Advertisements
