How do I move the seats with no power...
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, How do I move the seats with no power... in Past Cadillac Vehicle Discussion; Stopped by the yard an hour till close just to take a quick walk thru. I found something that a ...
    consigliori's Avatar
    consigliori is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Triple Black Eldorado ETC, 98 ETC(HG), 91 Seville(gone)
    Nov 2006
    Annexia
    42
    395
    Stopped by the yard an hour till close just to take a quick walk thru. I found something that a buddy of mine is in need of- the drivers side seat belt buckle. The seat is currently all the way back though, so I can't get to the bolts to undo it.
    Can I hotwire the seat control with a dewalt battery? That's what I usually use to test powered stuff like antennas and such. Not quite sure how to go about the seat though...
    blooddragon78's Avatar
    blooddragon78 is offline Cadillac Owners Member
    Automobile(s): 98 Seville STS
    Nov 2013
    Marietta OH
    38
    57
    Re: How do I move the seats with no power...
    Good luck, I'd love to know if you figure it out. My driver seat hasn't worked since I got my car. I would be happy with adjusting it one time and leaving it. I've tried jumping the ground, and power wires on the harness. Also tried jumping the serial data buss from the door to the seat, still no go.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    I upholstered the seat, in place, disconnected the drive shafts from the motor, and turned them manually, each a little at a time. Took a while. this was in a last gen Seville. Not sure if it would work for an Eldo.
  5. #4
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    The harness connected to the seat has:
    1. Thick orange wire -Battery voltage
    2. Thick black wire - Ground
    3. Purple thin wire - Data Line
    Assuming you don't trust the vehicle electrical system anymore and you can get to the wires underneath the seat (like dead central) then you disconnect the harness and apply the power to the seat directly (sure hope that seat is not in its lowest position).
  6. #5
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,126
    Go to junkyard, find similar connector that plugs into seat.
    Cut connector off, make jumper harness to battery.
    Plug jumper harness into seat that isn't powered.
    Move seat as necessary.....
  7. #6
    STS_Seville_Hunter is offline Cadillac Owners Enthusiast
    Automobile(s): 91 ETC, 91 STS, 98 Eldo Convertable, '93 Seville
    Sep 2008
    DHS/Palm Springs, CA
    29
    675
    I've hooked up a cordless impact battery to the fuse box.
  8. #7
    Nov 2006
    Annexia
    42
    395
    Thanks guys!
    I didn't get a chance to go after it yet, hopefully will in the next couple days.
  9. Remove Advertisements
