1992 Eldorado No Start Condition
Results 1 to 11 of 11
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1992 Eldorado No Start Condition in Past Cadillac Vehicle Discussion; Hello, I have recently purchased this 1992 Cadillac Eldorado. I am having trouble figuring out why it won't start. It ...
    Loom383 is offline Cadillac Owners Member
    Automobile(s): 92 Eldorado
    Jan 2014
    24
    8
    Hello, I have recently purchased this 1992 Cadillac Eldorado. I am having trouble figuring out why it won't start. It has a new battery, but when you turn the key it just clicks. Any ideas where to start? Thank you!
    delerium75's Avatar
    delerium75 is offline Cadillac Owners Fanatic
    Automobile(s): 1991 STS, 1992 Fleetwood, 1987 Maxima wagon
    May 2008
    Bay City, MI
    42
    276
    Re: 1992 Eldorado No Start Condition
    Clicking...like a continual clicking as long as you're holding the key or just one or two? How many miles on it?
    68
    82,063
    Could be a bad cable, but don't rule out the battery. I've gotten "new" batteries with a dead cell.
    2kflhr's Avatar
    2kflhr is offline Cadillac Owners Enthusiast
    Automobile(s): '10 Escalade, '97 Eldo ETC (Z)
    Dec 2004
    Mooresville, NC
    58
    889
    Or the solenoid/starter
    Jan 2014
    24
    8
    I have used multi batteries from other vehicles, still the same thing. Yes it clicks as long as I hold the key. It has 140xxx miles on it.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Time to start checking cables and connections.
    Jan 2014
    24
    8
    Thanks for all the ideas so far, depend on weather ill see about checking the connections/grounds and test the starter. Wish me luck!
    Jan 2014
    24
    8
    After looking over the car I have found what I believe to be two bad relays. When I first try to start the car I can hearing a clicking coming from the drivers floor after some research and looking for myself I found a relay that is for the starter. Also it seems with the key turned on but not in the run position there is a humming coming from the fuse panel on the LH side of the engine bay. After looking there are three relays located under the fuse panel. The one farthest to the right viewing from the front of the car back is humming. Anyone know what this relay is for? Also is there a test procedure for these relays? THANKS!
    Jan 2014
    24
    8
    So after replacing the relay it still seems to do the same thing. Acts like it has a bad battery, but I have replace and use multi good batteries. Could this be a security issue? When I bough the car the factory radio was removed, could this cause an issue? Thanks for any or all help!
    zentrade is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac 1993 Deville 4.9, 1991 Eldorado Touring Coupe
    Dec 2006
    370
    Is it turning over at all? ...I had a no start a few months back...turned out to be fuel injector fuse blown.
    Jan 2014
    24
    8
    I got it, it ended up being a bad starter relay located under the carpet on the drive's side floor.
  14. Remove Advertisements
