Crappy day with many problems - 1998 ESC - Page 8
Page 8 of 14 FirstFirst 1234567891011121314 LastLast
Results 106 to 120 of 203
Like Tree19Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Crappy day with many problems - 1998 ESC in Past Cadillac Vehicle Discussion; Originally Posted by Mafiaman111 Yeah, what MoistCabbage said, plugs that are not AC Delco will not last long. I currently ...
  1. #106
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,884
    Re: Crappy day with many problems - 1998 ESC
    Quote Originally Posted by Mafiaman111 View Post
    Yeah, what MoistCabbage said, plugs that are not AC Delco will not last long. I currently have Denso Platinum TT spark plugs in my caddy and 20K later there not looking to good and im starting to get a rough idle
    Take a look in your owner's manual, Specifications and Maintenance. You may find out that DENSO was the original plug in the engine. The newer AC Delco Platinum plugs for your engine - #41-950 - are made by DENSO - look at the box - "Made in Japan". (Same for my #41-987 - and my 2002 owner's manual lists the DENSO plug number, not the Delco)
    http://lmgtfy.com/?q=ac+delco+spark+...rence+list&l=1
    98eldo32v likes this.
  2. #107
    69
    82,286
    There are no set shift points, it all depends on engine load, speed, accelerator input, RPM.
    I can go through all 4 gears and never exceed 2000 RPM with a very light throttle input OR I can get each gear to shift at 6000 RPM with a WOT. The in between shift points are endless.
  3. #108
    Feb 2006
    56,884
    Quote Originally Posted by eldorado_sean View Post
    on my car there is a slider for the headlights? What happens when you put it halfway? Cause I always put it to the far right.
    Have you ever read the owner's manual section on features, headlights and Twilight Sentinel ?
    The GM service manual for your car lists several transmission shift points for throttle openings up to 50% - tested at specific loads and throttle positions. Otherwise, shift points are a fast moving target.
  5. #109
    eldorado_sean's Avatar
    eldorado_sean is offline Cadillac Owners Enthusiast
    Automobile(s): 98' Eldorado ESC
    Sep 2012
    Burbank, California
    740
    Ok so I just spoke to my dad and he said you can change the struts if you want. My front ones are GONE, so those will have to go first. Im scared to drive my car on the freeway cause the front bounces a lot when going over a bump at higher speeds. My rear shocks, I can't really tell, but I've said many times my ELC doesn't work. I know to do the soapy water trick but do I need a car jack to raise the car so I can freely move under the car? My teacher has one so I will probably go this Saturday to check em out. Previously said my dad has a parts store, so should we get it from his suppliers or go online to rock auto, amazon, etcetera.... I remember a part number like 90011 and 40046 but what are they for? I think a year ago I asked about them, but wasn't serious. The car has 170k miles so what else should I get and what brand( polyurethane or rubber bushing) those type of answers. My front ones are the priority and I hope when I put the new suspension I'll have an easier time coping with it.
    Also a friend of mine is selling his 2004 sls 54k miles black on black, not in that great of condition.( am i allowed to do that^^^^)
  6. #110
    Mafiaman111 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville 159k
    Oct 2010
    Pennsylvania
    449
    You will be fine with bad struts, Drive the car and enjoy it because buddy welcome to the real world with cars, everytime you turn around there will always be something wrong with your current car. I know this from experience I too am currently running on bad front struts and I still drive the car like I stole it.
  7. #111
    Sep 2012
    Burbank, California
    740
    Not sure if this is correct, but doesn't driving on bad shocks wear out your tires more? And isn't it dangerous? This car has 171k miles and I'm scared to even go speeds above 60mph. Can a shock randomly give out? Like a sudden collapse? And is your suspension still original from 98?(mines a 98 )my bushings in the back are all cracked and the thought of me driving this like I stole it gives me shivers of how much $$$ I risk spending if something gives out.
  8. #112
    Oct 2010
    Pennsylvania
    449
    I never noticed the tires wearing out quickly but worn out shocks i'm sure are dangerous and yeah I have seen shocks go out randomly. My suspension is half original, I have changed parts gradually my next big step is to change the front struts but thank god I have the FE1 suspension. My bushings in the rear are all cracked too. Anyway, I was your age when I got my first car which was this eldo and boy was with problematic but it never broke down on me (knock on Wood) and I fixed her all up and she has never ran any better.
  9. #113
    69
    82,286
    Badly worn shocks can cause ecessive tire wear (cupping).
    No. The shock doesn't support the car anyway. It simply dampens the rebound when you hit a bump or dip in the road to prevent you from bouncing down the road like a yo-yo (THAT would be dangerous and hard to control).
  10. #114
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,705
    YES - absolutely TRUE -
    isn't it dangerous?
    YES - also 100% TRUE -
    sure - HOWEVER - you must understand what a shock/strut does -
    your car is supported by springs -
    shocks and struts simply stop the springs from bouncing -
    when a shock/strut wears out - the car bounces more than it should -
    well - yes - sort-of -
    IF you have a heavy load in the trunk - or rear seat -
    the air bladders are inflated - to raise the rear of the car -
    to maintain proper ride height - with that extra load -
    IF one of the bladders or one of the air lines suddenly pops/leaks -
    the rear could suddenly drop down -
    to a point that the springs alone are holding the body up -
    Monroe 90011 KIT -
    this includes EVERYTHING - except new springs -
    for BOTH SIDES - for the front of your car -
    the best price today is $167.56 - with free shipping -
    http://www.amazon.com/gp/product/B00...A1ATZ3MAARQNEF
    CAUTION -
    Monroe is changing how this kit is sold -
    the original 90011 KIT has everything for BOTH SIDES -
    just like the kit I posted -
    the new packaging have only one side -
    90011-1 for the RIGHT - and 90011-2 for the LEFT -
    I mention this just so you don't think you are getting a real deal -
    and discover you only got one side -
    ANOTHER CAUTION -
    whoever does the installation -
    MUST FOLLOW THE INSTRUCTIONS TO THE LETTER -
    if not - the front end will sit almost 2 inches too high -
    the Monroe 40046 is the correct air-assisted rear shock for your car -
    $102.78 each - with free shipping is the best price I found -
    http://www.amazon.com/Monroe-40046-R.../dp/B0047D9TS0
    if the ELC system is not working properly -
    you can use the manual-fill kit - AK29 -
    to inflate/deflate the rear shocks manually -
    the AK29 kit is $12 - also on amazon.com -
    one more thing to consider - SPRINGS -
    with 170k miles - the coil springs could be getting weak -
    I recommend MOOG springs -
    front -
    MOOG81086 - $59.16 for the pair - with free shipping -
    http://www.amazon.com/Moog-81086-Coi.../dp/B002VJYAQS
    rear -
    MOOG 81005 - $80.42 - with free shipping -
    http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
    MoistCabbage likes this.
  11. #115
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    ^^^This^^^ All of it.
  12. #116
    Sep 2012
    Burbank, California
    740
    Ok I decided to tint my windows again. Anyone have a picture of an eldorado with window tints? I'm thinking about limo tints in the back 3 and 30% on driver and passenger window. The limit is 35% in California but I dont want my windows to look too different
  13. #117
    Sep 2010
    East Boston MA.
    29
    26,323
    If 35% is the limit, limo tint is illegal. You're a young kid, you WILL get pulled over.
    It looks better when all the windows match anyway. Go 35% all around.
  14. #118
    Sep 2012
    Burbank, California
    740
    Actually the law for ca is you can't touch the windshield at all, driver and passenger window is 35%and the back windows can be WHATEVER you want.
  15. #119
    orconn's Avatar
    orconn is offline Cadillac Owners 10000+ Posts
    Automobile(s): Cadillac 95 STS, 02 SLS
    Oct 2007
    Midlothian, VA
    73
    13,792
    From what you have been saying it sounds that window tinting should be pretty low on your priority list.
  16. #120
    Sep 2012
    Burbank, California
    740
    "Attempted a WOT" I saw videos of a eldorado doing 0-60 and it was a lot peppier than my car. Isn't it supposed to downshift or something? Sorry for the horrible video was kind of hard recording and driving at same time.
    http://youtu.be/qFF4IxcOmX0
  17. Remove Advertisements
